Question about Compaq Evo D310v PC Desktop
Non-system disk or disk error
When i turn on my compaq presario 6000 it comes up with a black screen and says non-system disk or disk error replace and stike any key....
Is there a way to fix this
  • 2,985 Answers
Ththe comuter is presumably fdinding a disk at boot up.
Ensure there are no disk in the drives.
Posted on Dec 29, 2007
It's either the MBR damaged, or the good old fashion "must be master or slave." Check if the HD is visible in the bios. If it is, try to save you data first with any type of pe disc (some even let you scan and fix the mbr), and a flash or portable hard drive. Next install windows or fix the mbr. If it's not visible, check the motherboard connectors of the ide cables. Make sure nothing is bent, then set your drives to slave and master. Even if it's a single drive set it to master. Last but not least, check your boot priority. Make sure either the cd or hd is first.
Posted on Aug 29, 2012
Non system or system disk error
Bad HDD? Have you tried a system restore/recovery. Reboot, at preboot repeatedly tap the F-11 key try to get to system restore/recovery.If it's an old machine you may need to replace the HDD.
Nov 06, 2012 | Compaq Armada M700 Notebook
My Compaq Presario CQ50 laptop won't boot up. The compaq screen comes up then it just goes to a black screen with a cursor at the top. I tried to run Norton Internet Security 2010 but all it does is ask...
Try another hard drive in the system, sounds like the drive is going bad, then after replacing the hard drive, then go ahead and recover the system. Bad sectors on a hard drive can make it where it won't restore.
If you can get your hands on a windows boot disk, then you can try to format the hard drive, wiping it out and installing it can fix that problem as well.
Apr 19, 2010 | Compaq Presario CQ50-215NR Notebook
Hey folks, first time poster here. I have a HP Compaq 2710p Tablet PC. The error is "Non-System disk or disk error. Replace and stike key when ready" Is this drive toast or can the data be recovered? If...
Normally this means the cpu is trying to boot from your cd drive and it is a non system disk in the drive. When you boot your cpu open the drive and make sure it is empty. If so if you have any other disks or mem cards in the cpu then remove them and your cpu should start up. If this is not the case, let me know and I will help you further.
Nov 10, 2009 | Compaq 2710p Tablet PC
Compaq presario sr1313cl pc desktop will not boot I tried recoving will not work when I start the computer up the logo screen will come up follow by a black screen w/blinking cursor in the top left corner...
Hi there
can u try to boot into safe mode f8 if not boot into bios than go to your harddrive area and see if it can find your harddrive and try the default settings and save and reboot also make sure there is no cd rom in the drive and there is no floppy in the drive
Mar 05, 2009 | Compaq Presario SR1313CL PC Desktop
Compaq n620c evo laptop
Check your floppy drive and see if there's a disk in it and remove it. If there is no diskette in the floppy drive and you are still getting the error. You can go into the Bios and turn off the "boot from floppy drive", that way it will not look for the floppy drive when booting up. Hope this helps.
Feb 27, 2009 | Compaq Evo N620c Notebook
Compaq evo n610
Your problem is that MOTHERBOARD can't detected HDD.Try with another hdd and let me know if it works!!!
Apr 04, 2008 | Compaq Evo N610C Notebook
Compac presario 1500
You need to reboot using the first disc in the series. Make sure that the AC adapter is plugged in, and check your bios settings and disable any power managment settings, in order to prevent the machine from going into standby, sleep, etc.
You should be able to make it through the entire series. If you can't, you may need to contact HP for a new set of discs, or if you have an HP authorized service provider, such as a Staples, Best Buy, etc; they can usually get the CDs a lot faster, and usually at the same cost, or maybe a little higher.
Jan 26, 2008 | Compaq Presario 900 /1500 Series EVO...
Compaq Evo D310v PC Desktop Logo
430 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
