AC unit not running
We have a split system unit FMU4460N6l
The unit fires up for about 1 or 2 secounds then shuts down.
The power light will flash once and stop for @ three secounds then flash 4 times.
hope someone can help me fire this unit up as it's starting to warm up.
we have 4 indoor units of this outdoor unit.
  • steveke Dec 30, 2007
    Thank you all fixed My Auntie is extreeeeeeeeeemly thankfull
    Problem Solver:
  • 12 Answers
Sounds like the unit needs a cleaning
you should call your local service man to do this
Posted on Jan 01, 2008
    Problem Solver:
  • 16 Answers
I dont have the book with me but that flashing light is giving you a code description of what is wrong. If it is only firing up for 1=2 seconds or 1 minute...be as specific as you can. this will help narrow the issue down. without having diagnosis book with me i would say on a 1=2 second shut down may be a couple of things. first power it down as mentioned above. we all have power surges and brown outs only some equipment is more sensitive to this and feels the affects, which you may have seen. secondly if you get a second set of sequences on that blinking light that will tell you there is a second or even third issue. on a possible second issue,,, check the condensor unit (outside unit) there may be something blocking the intake side of the unit causing the high pressure switch to trip (common) clear away what ever is there or even wash out the coils, of course power down the unit and only wash off the coils DO NOT WASH OR WET ANY ELECTRICAL EQUIPMENT. you do this at your own risk. next if you are able to get the unit to turn on for a minute get the the smaller size line that feeds the inside unit...it will probably be wrapped this is the low side and when the unit kicks on you should feel this line get cool or if you cant get to it check the high side and it should be hot. be careful when touching the hight side it can burn if you dont feel the cooling you probably have a leak and the unit will need to be reviewed/repaired/and recharged once repaired by a tech. if you are using a remote thermostat...do the common sense thing and check the connections especially if its a newer unit.
finally if none of the above took care of your issue. please call a qualified tech.
I hope this helps narrow things down and saves u some money as always you can contact me.
good luck
K.
Posted on Dec 30, 2007
  • 236 Answers
Try to off the power supply(circuit breaker) to reset the error and on again and start the unit. But if the symptom's persist you have to call for a qualified technician.
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Error flashing light on Totaline split unit air condintioner
You out door unit is not receiving power adequately. Most of these kind of issues are power related. Eg fluctuations, power unit strength, stabiliser problem or could be an issue with the supply from your mains. 12_1_2015_11_05_14_am.png
Jan 28, 2014 | Heating & Cooling
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
We have a 24DMC split air conditioner and it will not start up. The green light on the wall unit flashes 3 times followed by the orange button flashing 3 times. Can u please help?
A repairman just left and the problem is, I think resolved. The solenoid on one of the mini-split units was malfunctioning. It was telling the units that it was open and functioning but was actually not working for one of the two units, and caused the main unit to shut down. Once the problem was isolated and the unit fed by the faulty solenoid was shut down, the other unit functioned perfectly. So we now have half of the cooling for the house, but better than none, until we can get the part and install it.
Jun 28, 2011 | Comfort-Aire DMC24SB Split System Air...
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Power comes on for a secound and then shuts off
Try this:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If not, contact HP or local service center. It is a hardware problem
Jul 26, 2010 | HP Mini 2140 Notebook
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Fan motor
I have the same problem with mine, I would love to know what to do to fix it. I have turned the machine off at the power box.
Mine is a Kelvinator split system
Jul 13, 2008 | Heating & Cooling
Heating & Cooling Logo
253 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
