Question about Brother SE-270D Computerized Sewing Machine
Non-system disk or disk error
When i turn on computer it comes up with a black screen with non-system disk or disk error replace and strike any key
  • srbono May 27, 2008
    Hy. I`ve similar problem. I don`t have any disk in unit A or CD.
    How can I go into setup zone to change the start secuence.
    Thank you
  • ellipsis23 Jan 30, 2009
    I boot up my laptop Compaq 2510p this morning and it gave me a blk screen and a message that says "Non System Disk Error or disk error" checked the dvd rom , it's empty, I went to Computer set up (F10), Diagnostics to do a HD test but in my surprise the HDD Self Test Option is not highlighted and cannot be access, does this means that my HD just crash and needs a new one? I got a 100GB HD. Any suggestions? Please help! Thanks. : )
If your'e not using your floppy drive u may disable this drive. just hit DEL key and goto the SETUP locate the floppy drive and select disable. then check if your harddrive and optical drive are deteced property by selecting auto detect. the save the changes and restart your pc. If same thing happen observe the sound if u heard some annoying sound " tiktak..tiktak..tiktak..!" your harddisk could possibly be damaged..-
Posted on Dec 29, 2008
I have the same problem as above.Please help me fix it.
Posted on Dec 06, 2008
It sounds very much like you have a floppy disk in the "A" drive.. remove it and try starting the computer again...
Posted on Jan 03, 2008
ADOGG
AWESOME!
Oh my goodness. You are genius. I am almost embarresed to admit to anybody I had a floppy in the computer, much less that I own them. (Most people dont even use them any more) So I just spent 30 min on the phone with my IT guy and set up an appt for a house call. Which he will probably would have charged me an arm and a leg. re. You were absolutely right and I thank you.
God Bless you. ; D
Posted on Nov 11, 2008
The usb ports does not work how can i fix it
Seriously USB ports with Mac OSx on sewing machines ?
1. What is your error message on screen.
2. Have you checked the usb stick on any other computer ?
3. backup and initialize.
how to repair non readable USB on mac
Apr 16, 2016 | Sewing Machines
My screen is black.
A component may have failed. Perhaps requires service.
Make sure the screen hasn't been accidentally dimmed.
Feb 08, 2016 | Sewing Machines
Rcs on janome mb4 went black but seems to be working
RCS appears to be Remote x Screen.
Manual is shown below. error start on page 80
You may have lost the electronic connection to the screen.
http://janome.com/siteassets/support/manuals/embroidery-models/inst-book-mb-4en.pdf
Apr 05, 2015 | Janome Sewing Machines
Bernina 180E Touch Screen Dark, machine light won't come on.
I don't know the circuit of this sewing machine but it gives me the impression the light and the board are in series with a fuse. If this is true the light will burn out and cause the screen to go black as well. If the fuse would go out the same thing would be true. Anyway, change the light first. If this doesn't work you will need to replace the fuse. If there are still problems it will need the mother board to be replaced. Tell me how this worked out.
Oct 24, 2014 | Bernina Artista 180
Installing software
Delete all prior programs. Go to singer and find the patch for it prior adding the disk. It happened to me twice and finally I was able to do it when I deleted all prior futura programs. Hope it helps.
Nov 12, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
PC Designer disk not working
Your PC's floppy disk is not readable by the disk drive, probably because you don't use the drive as much, and it has gathered a layer of dust and dirt inside. It's necessary for you to clean the floppy drive using a special disk with a special cleaner liquid. However, with floppy drives going the way of the dinosaurs, it may be difficult to find such item nowadays.
Try getting one of those small compressed air canisters to clean your keyboard and try blowing the dirt off the mechanism of your drive.
If that fails, it's possible your floppy disk has gone bad. Data on these disks have only a certain life span measured in years.
If that also fails, then write to PFAFF and ask for a replacement disk of the same version of the software, sending them proof of purchase, etc, so that they will comply without any questioning.
Aug 03, 2009 | PfaFF Creative 7570
Janome 8000 on but witout functioning
Turn on the power switch while you are pressing the start/stop key,reverse key and auto-lock key.The LCD screen indicates(Press + Mark) You should see a ( + ) on the screen.
Press the center of the plus mark with a non-sharp object. The mark moves and the machine beeps.Do this until the screen says Adjustment END.
Turn off the power switch. Wait 10-15 seconds and turn on the power switch and see if you can select stitches.
If this doesn't solve your problem and you can see the patterns on the screen you have another problem which will probably involve a visit to a technician either Janome or Elna trained(Model CE20)
If you can't see any patterns or they are faint then the LCD board needs to be rebuilt and an authorized Janome Dealer can remove the board,send it to Janome for a rebuild and reinstall it for you.Plan on spending more than $300 for this. If the machine works well, it is well worth if as it is a very nice machine.
sewman7
Nov 05, 2008 | Janome 8080 Computerized Sewing Machine
General disk error reading when i insert a disk
Look at the floppy disk using Windows Explorer. You should see something to the effect of menu1, menu2, menu3 menu4 and one or two files with a file extension of something like .mhv or .phv . Inside the menu folders, you will find the .shv files.
Just writing the .vip or .hus to the floppy will not work.
Keep me posted and I'll try to come up with something more.
Oct 01, 2008 | Husqvarna Viking 1
Pfaff 7570 creative card
Hi Eva,
You should be able to clear the card by holding down the card key as you turn on the machine. You should then be able to reformat.
Linnette
Jun 11, 2008 | PfaFF Creative 7570
Brother SE-270D Computerized Sewing Machine Logo
174 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
