Sony FD Trinitron WEGA KV-27FS120 27" TV
Problem for Sony FD Trinitron WEGA KV-27FS120 27" TV
I have two Sony KV-27FS120, they have the same
By Cailloux on Oct 19, 2009
I have two Sony KV-27FS120, they have the same problem, 4 blink, both have no vertical & horizontal drive from IC001 jungle chip, and Q505 horiz output blow. Circuits between them look good. I replace IC001 M65582AMF-105FP part #680493702 by sub M65587MF-105FP part #680668701 from MCM electronic store. I verify the flyback with a flyback tester, say good but is not sure at 100%.
I try on one TV, Q505 blow up again and IC001 still have no drive output.
So, what's going on???
Why IC001 blow again???
Thanks to help me.
Comments:
Oct 20, 2009
- For the first time, When I check the circuit, IC001 & Q505 was defective. I replaced IC001 & Q505. Turn on power, Q505 blow immediatly and i got no Vertical & Horizontal output on IC001. I have a scope and the manual, there is no signal. Transistor Q505 is an original. The card has not suffered from heat, no cold solders arround horiz. drive transformer.The question I ask myself, why IC001 is defective for the second time? The IC is expensive $ 33. Any other suggestion? A guy in another forum had the same problem, he does not know the cause.
Oct 23, 2009
- I made a mistake not checking jungle chip output without horiz o/p transistor (open the collector). I appreciate your last statement is professional.
Best Solution
posted on Oct 19, 2009
Very Helpful)
johnnydiode
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 94%, 198 votes
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Comments:
Oct 20, 2009
- I don't know why your IC blows but my suggestions were all valid. Idon't know why you rated me saying I was off topic - I guess that will teach me for trying to help!!
Oct 20, 2009
- I know you had no Horiz. drive - I should have said unload the horiz o/p transistor (open the collector) and then momentarily turn on the set with a known good IC. I realize it's an expensive IC and the possible reason it may blow is that when one of the secondary voltages from the flyback -once started - may be too high or have to much a/c ripple (poor filtering). with the Horiz o/p unloaded you can chec at least the signal. I have worked on many of these sets b4 and was pointing out the common faults. Some times you can't even see that the horiz. drv tranformer has cold solders - I just unsolder all leads and resolder and always change the drive cap because frequently it will mis shape the horiz. freq signal causing overdriving - which blows the o/p.
Sorry,I should have explained better originally
Good luck, post when you find the answer or have any questions
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" In my first post I said: No horizontal & vertical drive from IC001 jungle chip. And I say a little further: IC001 still have no drive output. I obviously checked with a scope. You suggest: with a scope compares the drive signal shape?? Something wrong with your analysis. Thank you anyway. " - Cailloux
Popular Solutions for Sony FD Trinitron WEGA
Questions and Unsolved Problems for Sony FD Trinitron WEGA
Do you recommend Sony FD Trinitron WEGA KV-27FS120 27" TV?
Answer
Answer
There is a strong vertical line pin-cushion effect. Also, the aspect ratio does not adjust so many... (More)
Answer
i have bad reception, the antena internal plug converter to cable plug seems to be defective it... (More)
Answer
Just got a new TV and want to sell this model. It's in great working condition. How much do you... (More)
Answer
My Sony KE-42TS2U screen comes on and menu displays however there is no picture. The stand by led... (More)
Answer
I have KV27S42 model Sony TV. When power on it blinks 4 times and then a break and again 4 blinks.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony FD Trinitron WEGA...:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
