Question about Epson Stylus C43SX InkJet Printer
Epson c43sx not printing
My epson c43sx does not print.
i used ssc service utility
it says printer off or some other problem my printer is connected
ned help
  • Anonymous Feb 21, 2008
    same problem. the tool says printer is off or some other problem. any solution?
    Genius:
  • 2,985 Answers
Make sure tiy have set the utility tocyour model of printer,
Make sure all connections are correct.
Reload the software.
Does the printer give a message of some sort?
Posted on Dec 29, 2007
Message came up on my computer saying i had to take printer to service agent as parts had reached their service life ,rang epson & they told me needed to change wasting pad ,quoted around 300 any...
Try the SSC Utlity, download link is on the bottom of this page:
http://www.ssclg.com/epsone.shtml
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 07, 2011 | Epson Stylus C43SX InkJet Printer
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer service is over
This usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Mar 30, 2009 | Epson Stylus C43SX InkJet Printer
Refilling Epson T0794
Try installing this utility: SSC Service utility v.4.30. The Epson status monitor will try to get in the way. Follow the instructions and disable the Epson status monitor after you install this program.
Jul 09, 2008 | Epson Stylus C43SX InkJet Printer
Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
Jul 05, 2008 | Epson Stylus C43SX InkJet Printer
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx red ligh on
my printer does not print.
i used SSC service utility
it says printer off or some other problem.
what should i do
Aug 13, 2007 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
178 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
