Question about Protron PLTV-32 Television
Protron 30 inch back light
Back light turns off after one second in on position.
    Problem Solver:
  • 10 Answers
It is first important to have the three question answered.
Posted on Dec 31, 2007
  • 579 Answers
How old is this unit?
Did this happen suddenly or has it been intermittant?
Do you still get audio?
How would i deactivate the security system on a 1999 chevy caviler
Try to reset security manually. Make sure battery is good. Insert key into ignition turn to on position (make sure to "bump starter"every time you turn to on position). Leave in ignition for 11 minutes. Security light should go off before proceeding to next step. Turn key to off position for 30 seconds. Then turn back to on position for 11 minutes. Then turn to off position for another 30seconds. Then turn to on position for another 11 minutes. Then turn to off position for 30 seconds. Turn key to on position again for 30 seconds. Start engine. That should work if every thing is compatible
Oct 20, 2017 | Cars & Trucks
Will not start
Hey Sidney. On G6 it has a pass lock anti theft- in which your key is programmed into the computer. If the key is not programmed into the computer or ECM, then nothing at all, heres the steps, and where it says a new cut key on 1, ignore that, just use your key, and also you will need to take your g6 into the dealership and have them reflash the ECM, and program the VIN number into your new ECM, if not it might throw the check engine light.
1. Insert a new cut key in ignition and turn key to the ON position for
10 minutes and 30 seconds.
2. Within 45 seconds turn the key to OFF and then back to the ON position for
10 minutes and 30 seconds. 3. Within 45 seconds turn the key to OFF and then back to the ON position for
4. Turn key OFF then back ON. The key is now programmed.
Start vehicle to test key.
Mar 22, 2014 | 2008 Pontiac G6 Sedan
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
Sep 08, 2012 | 2000 GMC Yukon Denali
Protron PLTV-32C, Model No. LT32C1P1 just went black as we were watching. It did it last night but within seconds the picture came back on. Now it went off and is staying off. Didn't realize at first but...
Mother board Is My Guess That's What's Wrong With Mine And Part Is $250.00 My Problem IS Can I Replace it By Myeslf . I Had Mine looked At .By So Called Professional He Kept it For 8 Months.
Aug 31, 2010 | Protron PLTV-32 Television
Hello, i just got a protron flat screen tv from an estate sale. i try to turn it on, and the light goes from green to yellow and stays. tv did turn on one time before. what is wrong, and is it worth...
Please post back the model so we can help you more.<br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt"><a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href=""></a></span>
Aug 24, 2010 | Televison & Video
Protron 26 inch lcd.....turn on, picture flashes on for a second or two then screen goes still functions ok...tried unplugging to reset...doesn't work....any thoughts
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Please post back what you find.
Dec 23, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Aztek won't start,key locked in ignition, service engine light on
It is the security chips in the keys. Has this car been wrecked? Was this car made in Mexico? GM had the bright Idea of creating a security system that would do exactly this, I know on cars made in Mexico (like the HHR) You can reset the power and get the key back out, but vehicle will have to be reprogrammed with the master key. This involves turning the key from off to run position without ever going past run (i.e. start position) leave key in this position for 30 minutes. Turn key back to off for 30 seconds then back to run for 30 minutes. repeat this step three times. the last time, after 3rd 30 minute period, turn key off for 30 seconds and then try to crank. Please note this only works if the original master key is being used. You can then reprogram the second key following a similar sequence, only master key that is working has to be inserted to let alarm system know that vehicle is not being stolen only that you are trying to reprogram a key. If original master key is not being used then vehicle has to be taken to the GM dealership to program keys and possible key module replacement.
May 30, 2009 | 2001 Pontiac Aztek
Need to know how light pilot
First step turn the thermostat off. It is very important.
Next find the knob on top of the gas valve you will see writing on it turn it to pilot it could be in the off position so move it to pilot depress the knob where it goes down about one inch. Take a long lighter long match or something like that and hold at the pilot it will be back in the furnace by the front of the burners. Once the pilot lights hold the button for another 30 seconds. Release the knob now the pilot should be on and the next step is why you turned off the thermostat rotate the knob to on position. Go to the t-stat and turn on the heat.
Nov 27, 2008 | Heating & Cooling
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
