Question about Sony Xplod XM-554ZR Car Audio Amplifier
Car amps i need help with hooking up a Sony Xplod XM-554ZR 600 watt amp witha scosche silver amp wiring kit to a 96 honda civic dx
  • Anonymous Mar 14, 2014
    how do i hook up the wiring on my amplifier
Important is to hav correct wires and groud cable...
Posted on Dec 29, 2007
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
    Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
    May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
    The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
    Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
    sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
    Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    How to measure watts
    You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
    You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
    Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
    Red light
    something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
    Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    No response from amp
    it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
    Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony xplod xm-554zr amp
    try disconecting ur battary for 2 min and try it again
    Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony Xplod XM-554ZR Car Audio Amplifier Logo
    197 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
