Question about Motorola Mobility W375 Cellular Phone
Sound fx Hi again Just wondering if there is a way of putting your own sound/ring tones on the phone, like a sound track or sound grab of your own choice??? Cheers
  • lozzzj Jan 08, 2008
    Hi Gaz
    Much appreciated, thanks for the info, have a great year.
    Cheers
    Loz
    Scholar:
  • 103 Answers
You can, but with the w375's tiny memory (500kb, that's right half a MB!) you need to be clever & make an edited, compressed mp3 to drag & drop into the sounds folder.
So, you'll need a sound editor. If you have Nero, you already have one, it's called Nero Wave Editor. Soundforge & Audacity (which is free) will also do the job for you. Open up your chosen mp3 in the sound editor & cut the file down to the best 20-30 second snippet. It's a ringtone so you won't need the whole song. When you have your edited snippet, normalise it in the sound editor & save it as a 40kbps MONO mp3. There's no point in making the bitrate any higher as you won't hear the difference on your phone's speaker with most types of music. The file you have just created will be 100-150kb & should fit onto your phone's tiny memory without any problems (so long as the phone isn't already full of photos or other files).
If you need help connecting your phone to your computer via USB check the other questions or just shout!
Posted on Jan 08, 2008
You may find it easier to use an online editor rather than Audacity.
Try http://makeownringtone.com
Never had any problems with it.
Posted on Jan 25, 2008
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
Jul 10, 2007 | Motorola Mobility E815
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Incomig calls are exremely low volume outgoing calls have normal volume. Is there an adjustment for this
hi
you can increase your sound by increasing the sound in profile settings.there you can find increasing sound for your ring tone.moreover you can set the ring tone that should have increased quality of your sound.then check the sound in call option.mostly samsung phones speakers have low sound quality
thank you
Dec 17, 2010 | Samsung SGH-A877 Impression Cell Phone
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
Ringer Help
Hi there, don't worry changing ring tone it's a very easy task. All you have to do is go to the main menu on your phone. From there you wanna go to settings, and you should see and option there to change the ringtone. In the other hand if your phone has sound files that can be used as a ring tone, then all you have to is go to the location of that file (it's usually located under "my stuff" "my music" etc) and select the file, from there you can select that file to assign as a ring tone. If you need further instructions you might want to put the make and model of your phone. Good luck!
Jan 19, 2008 | Lands Phones
Motorola Mobility W375 Cellular Phone Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
