Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Can't access router via 192.168.1.1
I set a wep password and did not ind the manual till later that I was meant to write down all 4 codes. I was then unable to log into it at all. I manually reset using the button on the back and now while I am connected I am back to square 1 - unable to secure the network but worse off than before as I am unable to access the router via the address above.
  • Simon Middlemass Dec 29, 2007
    I have reset the router but i am now no longer able to access via 192.168.1.1 - it times out.
    I also do not seem to have a EZsetup disc - I am running OS X 10.4.9 if that makes any dfference
    I have reset the router via a button on the back - but i am now no longer able to access the router via 192.168.1.1 to set up a password - it times out.
  • 689 Answers
Hi Again
Answer is simple; network security (WEP or WPA) key is different than regular password. Entry should be Hexadecimal, However you can use pass phrase generator by entering regular characters or you can enter directly. For example if you we want to put to "password" as network key hexadecimal input will be exactly 2B204A3F1042643E480FDD655E for 128 Bit WEP. Since you are unable to reach the router. Please reset it first. so it will be accessible from your computer without Network key. Network key will be enough for the 1st line
Hope you will resolve the issue.
Good Luck
Posted on Dec 29, 2007
Need to identify a lost password to access my wireless network
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 01, 2011 | Belkin Computers & Internet
Wpc54 g need to conenct via WPS - only offers wep
You can configure WEP in your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 27, 2011 | Linksys Wireless-G WPC54G 802.11g/b
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Someone is acsessin my router and useing my internet without my permission i need to change the password but i cant
Reset both password (1) pasword for access router via GUI (2)Wi fi security password WEP or WPA or WAP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Apr 17, 2010 | Belkin Computers & Internet
Network to include: PC1 that stores all shared files and is connected to printer and scanner. PC2 that can access shared files, printer and scanner via PC1. PC1 & PC2 are hard wired to the router...
You have to configure password for WAP to access the network. For this go to router management and configure the WAP password.
Revert back for more assistance.
Feb 01, 2010 | Computers & Internet
Reset router and add a new netkey . I have a Router G MIMO Plus. Model F5D9230-4. I move my office and I lost manuals and CD installation. We also change computer so we forgot the netkey. How can we reset...
You can secure your wireless network wit WEP or WAP code.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Dec 10, 2009 | Belkin (F5D9230-4) Wireless Router...
Where do I find my WEP key
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your change
Nov 21, 2009 | Linksys Wireless-G WRT54GS Router...
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
I have a netgear wireless router, I also have a new PS3, I want to access the internet via the PS3 but have lost my WEP key for the router. Whats the easiest way of finding the WEP key Thanks Darren
wep key or router administrative password?
if you have router admin password, you just go to your router settings and reset, delete all WEP key setting
(i assume one that connect to your router is only the PS3)
The setting should be web-based.
connect a pc to your router using LAN/ethernet port.
Access the router (you should know the router
ip address) via IE ex: http://192.168.0.1/
Read your router manual for details.
Dec 26, 2008 | NetGear MR814 Wireless Router
Wep code
Hello. You need to enter the WEP code that is set on your router. to ind that go to your PC and open Explorer or whatever you may use. Type in the address bar 192.168.1.1 and enter your router then click on wireless settings and the WEP code should be on the page. Hope this helps. Good luck and happy gaming!!
Oct 08, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
207 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
