Question about Sony Playstation 3 (PS3) Console
HDMI causes red lines (static?) on screen
Occasionally after the connection between the tv and ps3 is reset (for example when starting/ending a game) the screen will have very thin and numerous red lines horizontally. i've tried switching hdmi ports on my tv, but nothing. i bought my cable cheap off the internet, could this be a consequence?
  • 3 Answers
Im having the same problem to fix it i unhook my cable box (the video cables and the hdmi inputs to the tv) this stops the lines--try just the ps3 hooked to the tv and no other devices this should solve the problem--must be getting interference from some device
Posted on Oct 06, 2009
    New Friend:
If anyone has issues with a red line jumping around intermittently on their screen, try changing the HDMI cable out. I've had 3 crapped the bed this way. Do this before you replace a tv or console, it could just be your HDMI cable crapping out.
Posted on Sep 12, 2017
  • 36 Answers
Try to borrow a HDMI cable from someone else, or try yor setup on another HDTV, and sdee if the results are the same, then at least you can narrow down the problem to the TV or the cable.
Posted on Dec 29, 2007
Hi, we have a ps3 we play Black Ops on. Its connected to a Sony Trinitron tv w/composite cables. Lately, the picture has been very hazy and dark, no bright colors like it used to be. Its hard to see where...
green sounds like a TV problem if persists with other games could be TV but im kinda thinking it is ingame settings occasionally updates can reset picture settings in the game i think for black ops it had some kind of adjust brightness until you can't see this object in background and sometimes it helps to go back and check that only other explanation would be you went to different resolution ex: 480, 720(hi def), 1080(highest high def)
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Screen says "format not supported"
You need to lower your PS3 video resolution, Google the web on how to change the PS3 video resolution.
See examples here:
http://www.youtube.com/watch?v=JHQnpyIE7sE
http://manuals.playstation.net/document/en/ps3/2_20/game/output.html
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Right now it is too high for this small TV to display.
Nov 19, 2010 | Sylvania LC195SLX LCD TV
Everything connected, the screen shows but the
Try connecting the PS3 to your TV through a different port. For example, if you are using HDMI1 on your PS3, try HDMI2 or HDMI3.
Try a different cable. If you have a friend with a working cable try that.
Try a different output on the PS3. For example, if you are currently using the HDMI port, see if the standard composite or component output will work.
While convenient to plug things into an AV reciever, I find that just adds another link in the chain of devices that could go wrong.
Good luck.
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
MY PS3 DOES NOT SEEM TO BE WORK WITH THE HIGH DEFINITON CABLE IT CAME ON FORA FEW SECONDS THEN SCREEN COMES UP WITH NO SIGNAL????
This usually happens when you first buy your ps3 and try to use the HDMI connection immediately. The problem is that the ps3's default output resolution is set to 480i out of the box, and when you try to use an HDMI connection first, HDMI can't do that resolution. HDMI only does 480p, 720p 1080i and 1080p.
See :)
This also happens if you move your ps3 a lot. As it is, HDTV's are either 1080p (full HD) or 720p (including 1080i). If, for example, your tv is 1080p, when you set your display settings in the ps3 menu, it will set your XMB, or ps3 main menu to the max resolution of your tv, 1080p in this case. The resolution will automatically adjust when you start a game, and that game has a native resolution output. That's why, most of the time, games will play in 720p, because that's there native, or original, resolution. This is also the reason why sometimes people have no display on there TV, or a black screen, and when they play a game, that will actually display. That's because your tv can ACCEPT that resolution of that game.
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 screen flash / sound cut-out
The PS3 has an issue with what's called the "HDMI handshake" between the PS3 and the TV. The PS3 does not even realise that this is happening. What you might try to do is turn the system on, play a game, and when the flashing and no sound occurs, unplug the HDMI cable from your PS3, wait a few seconds and plug it back in. This may resolve your issue. If it doesn't work, try component cables, there is no known issue with this problem occuring with this type of connection. Good luck!
Aug 20, 2009 | Video Game Consoles & Games
PS3 start screen will not show up on my TV
I had this problem before. I messed with the settings on my PS3 and My TV until the settings matched. My PS3 would show the home until I loaded a game. I turned off then on my PS3 to get to the settings. My TV manual had the types of videos it supported so I went with the second to highest setting it supported and it worked. Hope this helps.
May 29, 2009 | Sony Playstation 3 (PS3) Console
Dvd or game not playing
If this is an issue you have always had (meaning you just started using the system) it may be a resolution problem. If your PS3 is set to display movies or games in a resolution your TV can't handle, you'll get issues like this. Go into your video settings in the bar and check to make sure you don't have it set for something your TV can't do. My TV, for example, won't do 720p.
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
Horizontal lines on my new tv when i use ps3
1 of 3 things, 1.) the easiest would be to try a HDMI cable 2.) Your PS3 video may be going out (try it on a diff TV) 3.) your Video inputs on your tv may be going out. Good luck to you!
Dec 28, 2017 | Sony Playstation 3 (PS3) Console
Thin line of colour run across tv screen
Got my mate to look at it ! He had to reset the factory settings for the HDMI (my son was'nt to chuffed as he lost all his saved stuff ) also the screen setting were set to a lower sieze? what ever that means ? but its solved the problem
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Is the playstation burned out?
Did your cousin ever connect it to an HD tv? If he did, this is a common problem with it. If you operate the PS3 with a normal television set, the ps3 will work fine. But when you connect it to an HD tv and hook up the HDMI cables, the ps3 sets itself to work with HD tv's only. There is a simple fix. a Hard Reset. Call sony customer suuport and tell them that your ps3 doesn't have a menu screen. They will walk you through the steps to restore your system. I would tell what to do myself if I remembered what to do. But regardless, remember this, every time you connect it to an HD tv and want to switch back to a normal tv set, you will have to hard reset the system. Try to remember the sequence the first time so that any other time this happens you'll know what to do.
Best regards,
Gavin93
Aug 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
3,586 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
