Question about SanDisk Sansa e250 MP3 Player
MTP problem Hi...I can put songs on my e250 through MSC with it as a removable disk, but when I switched it to MTP in order to do a playlist through Windows Media, my computer searches for a driver and is unsuccessful, making the mp3 player not work in MTP mode. I called Sansa, who told me to do an MTP porting download, which I did, and my computer STILL isn't finding a driver. This is driving me nuts! Also, when my mp3-er plays a video, it only plays part of the vid, and then reboots itself. The heck?
  • 8,596 Answers
Use volume + while connecting the Sansa to get windows to laod the drivers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
Posted on Apr 08, 2008
My sandisk says,"not enough space
"You need to format your device, the best recommendation is to place it into MSC mode. This is the Sansa's mass storage mode and it allows the device to be treated as a drive. Go to the settings menu and find USB Mode. There are two choices, MSC and MTP. Choose MSC. MTP is for music transfer using a media player software like Windows Media Player. If you don't have a way to set MSC mode with a menu on the device, engage the 'hold' switch, and while holding down the left or right button (others report also using the center button), plug the device into the USB connector. Make sure the USB is already plugged into the computer. You shouldn't need to do this with a standard e250; the menu should work. After you have connected the device in MSC mode, right click My Computer and choose Manage from the menu. Find Disk Management and select it. The disks should be numbered, starting with 0 for the C: drive. You should see a drive that says SANSA E250, or something similar. Write down the type of file system if it is shown. Most e250's says FAT32. Some are FAT, but check to be sure. There will be two partitions on the disk. The larger of the two is for your music files. The smaller is for when the device goes into "hibernation" - it's so you'll be back to the exact same song when it powers back on. Right click the larger partition and choose Format from the menu. You will see the format dialog. Set the volume label to SANSA E250 (I believe that's your device type), set the file system to what you wrote down earlier (do NOT choose NTFS!) and leave the Allocation unit size at "Default." Do not check either of the two check boxes. Click on OK. Keep an eye on the partition in Disk Management and you will see the percent complete. When it's done, look in the System Tray (by the date and time). You should see an icon for safely removing hardware. Double-click it to bring up the safely remove hardware dialog. Click on the USB drive representing your Sansa device and click Stop. Another dialog will come up and you'll have to do this again. Close the dialog when the device has stopped. The device will restart and initialize the music database. You're done! Now change to MTP mode and sync the device and add your songs back in. Whenever you are in MSC mode, ALWAYS stop the device as I described in the paragraph above. That way you won't corrupt the drive."
Thanks for using FixYa
May 26, 2011 | SanDisk Sansa e250 MP3 Player
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
I want to create a playlist on my SanDisk Sanso 250, but cannot figure out how. Can you help?
Sansa MP3 players have 2 modes, MTP and MSC. In order for playlist to show up properly on your player it must be in MTP mode. First, go to settings then USB mode or just mode( depending on the player). then choose MTP. Once it's in this mode, connect to you PC. Open Windows Media Player and go to the library. Right click on the song of your choice then go down to "add to" then click on additional playlist. Type the name of your songs and click ok. Right Click on the next song, click on "add to" then click on the name of you playlist. Continue this until you playlist is complete. Click on the Sync tab at the top and then click on sync settings. make sure "sync device automatically" is checked off. scroll through the large white box and only check off the playlist you want on the player. Click ok and the playlist will start to sync to the player. Once complete, disconnect the player select music then scroll down to playlist and you will see the name of your playlist...
I hope that helps
Please rate accordingly
Thank you
Dec 16, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Mtp mode
uuh no it dosent...nice try tho
Jan 05, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250
Well the SONGS folder might be hidden [happened to me]
Steps to see hidden folders:
-My computer
-Folder options
-Show hidden files and folders
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Playlist Problem !!!
The Sansa m200 series can only create playlists in MTP mode. on the menu go to settings>USB. There are two options MSC and autodetect. Once in autodetect your sansa should say MTP when connected to your PC. In this mode you should be able to add playlists without any trouble.
Hope it helps
Nov 23, 2007 | SanDisk Sansa m240 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
