Question about Frigidaire FEQ332E Electric Dryer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
So-- I have a Frigidaire washer and dryer from 2000 and stacking kit 5303937141... two brackets essentially - I'm looking for instructions to use this stacking kit at this time.
  • Anonymous Jan 28, 2009
    I have the same problem
  • Anonymous Apr 04, 2009
    no manual with the stacking kit so we know how to install
  • 4 Answers
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Posted on May 30, 2009
  • ultimateamc Nov 30, 2010
    looks like you also need to remove the original brackets that held the washer top on, they will be snapped in the washers lid, One has a screw that held it in place the other just floated in the slot on lid. remove these and they will be reattached as the back brackets that will secure the back of the dryer to the top back of the washer. if you look at the dryer there will be two slots that will align and then the new screw hole position will be obvious. they do not reattach in the same holes, the holes that will be used are inboard and in a position that makes the brackets about 2 - 2 1/2 inches closer together. hope this helps..... i will be finishing my oun install tomorrow after I pick up the new front brackets #5303937141 sears price $4.39. frigidaire wants $5.99.... I will pick up from who ever has in stock locally tomorrow.
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
How to stack dryer LEQ1442ES1 and what stack kit to buy?
Hello Friend, that's a great question!
The recommended stacking kit for your Frigidaire dryer (LEQ1442ES1) is part number STACKIT2. Further information regarding the stacking kit and directions can be found in the installation instructions listed below. Hope this helps! - Z
Frigidaire Manual Search Results
Sep 05, 2014 | Frigidaire Dryers
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
I am concerned about srewing the stacking kit to
Maybe, depends on the age of the washer; you should be able to use the screws that come with the stacking kit.... which screw into existing holes in the washer.
Nov 08, 2009 | Samsung Washing Machines
Stacking kenmores
Yes. When I bought my washer and dryer, it came with the stacking kit.
Jul 21, 2008 | Kenmore 44072 Front Load Washer
Need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Nov 24, 2007 | Frigidaire FEQ332E Electric Dryer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FEQ332E Electric Dryer Logo
3,007 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
