If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
when i try to burn a cd using real player it says it cannot detect a cd burner, what can i do to fix...
(More)
when i try to burn a cd using real player it says it cannot detect a cd burner, what can i do to fix it?
I have a prolem someone changed my password on the main screen so i can get into windows i do not...
(More)
I have a prolem someone changed my password on the main screen so i can get into windows i do not know it is there something i can do
hi I have an emachines comp. and the cd burner says insert a blank cd to burn even if there is a...
(More)
hi I have an emachines comp. and the cd burner says insert a blank cd to burn even if there is a brend new blank cd in the burner any suggestions
