Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
In a nut shell...Set it up, didn't work, then worked, then moved and now won't work
Okay, I am completely lost so I'm hoping one of you experts can help me.  I got my MacBook Pro in April and bought the D-Link WBR-2310 so I could have Wi-Fi in my apartment.  I also still at the time had a desktop that was a PC. I followed all of the instructions and the internet would work on my desktop but not on the laptop, in fact I couldn't open any files on the Mac.  My friend, an internet know it all came over and tried to help me, learned my ethernet card was bad in the PC and the internet stopped working in the PC but couldn't help me with my Mac and the Wi-Fi as he knows nothing about Macs.  A few weeks later, all of a sudden, the Wi-Fi started to work.
I just moved out of state about a month ago and set everything up except for my desktop as I just don't use it anymore.  The d-link router is not working again.  I'm sick of paying for internet I'm not using.
How can I reset my network and get this to work?
I am sure I gave more than enough information, but I have no idea.
Thanks in advance for the help!
    Problem Solver:
  • 8 Answers
If you would like for me to make sure you have everything setup correctly please e-mail @ Raptor_2k7@hotmail.com
Posted on Dec 29, 2007
On my dyson upright, one of the balls won't turn, and it's the one you can't remove
To remove the ball shell on that side you will need to turn the small round center cap counter clockwise. I usually stick two small Torx screwdrivers into two of the holes to give some leverage to turn the cap. Stick a flathead screwdriver in one of the slots of the nut holding the ball shell on to twist to remove the nut. Try to determine what is causing the resistance to the ball shell moving freely.
Dec 24, 2017 | Dyson Vacuums
I am missing all of the screws for the crib. We recently moved and lost all the screws for the crib.
Lowes carries most bolts and barrel nuts. Local small hardware stores may have longer bolts if needed. I sometimes use a bolt specialty business for unique bolts. Most cribs use either a metric set or SAE. If you are replacing the complete set choose whichever is easiest to find. If they bed has glued in threaded nuts go with the matching bolts style, metric or SAE.
Jan 15, 2013 | Delta Eclipse Dark Cherry Finish 4-in-1...
My atc fuse would keep blowing I put a bigger fuse it didn't blow that but I herd a zap noise from my TCCM now my 4x4 won't work 1999 jimmy
What you have done? You Just damage the TCCM and that's why you will not manage to shift 4x4. Why this happened? Because you had shortage somewhere and you receive blown ATC fuse.You put a bigger fuse in capacity where the was stronger to blown and the fault moved to the tccm system which was not protected and blown.Ask for an expert to check and see whether the fault is easy to get fixed.
Jan 02, 2013 | 1999 GMC Jimmy
Lost all files to s.m.a.r.t now can`t restore them
You didn't lose them you just lost the icons on the desktop and in the start menu. Bring your computer to a computer shop that specializes in virus and malware removal for a set price of $50 to $100. They will get all your icons and files to show up again. This is a nasty virus/malware so just bring it in to an expert.
May 30, 2012 | Gigabyte Computers & Internet
Car makes a click click but won't turn over..It has been cold
If battery is flat (discharged) that could be one of the problems. Charge the battery or try jump starting from another vehicle, if possible. If it still don't start after trying those two things, it's probably the starter gone bad.
If it starts after charging or jumping, have your battery load tested and
your alternators output checked. Make sure you didn't leave something on for example headlights or something plugged into accessory outlet, could be the reason battery went flat.
In a nut shell, one of these caused this. Bad battery, bad alternator, bad starter or something draiedn battery. Hope this helps.
Jan 18, 2012 | 2007 Chrysler 300 AWD Sedan
The main time on my ET70215C is 3 min too fast. How do I change it to the correct time?
Open following link for manual.
http://waterheatertimer.org/pdf/Intermatic-et70215cr.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Keypad is explained on page 4.
If you reset timer by holding down reset button and clear button, all programming will be lost.
So it is better to change data instead of clear all data.
Instruction manual says timer displays prompts that guide through steps.
So some steps are automated.
Page 3: Put RUN-SET slide switch into SET position to enter, review, or clear data
Two categories of of data: set-up and programming.
Page 4 suggests that putting slide switch into SET position will display each setting in sequence.
You enter data using keypad, and then okay data presumably by pressing OK button.
To save data, move RUN-SET slide switch to RUN position.
Additional resources:
1) Add a comment and I will respond.
2) Contact Intermatic:
http://www.intermatic.com/customer%20service.aspx
3) Take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Take a moment and rate answer:
Sep 02, 2011 | Intermatic ET70215C Electronic Energy...
Panasonic 1200btu air conditioner
you must check the fuse of pc board.its a glass fuse and propably had burned,replace it,if the fuse is ok then is the varistor and you must get an expert to fix it.
Oct 01, 2008 | Panasonic CW-C60RU Air Conditioner
CD player
It may be power problem/Lens cleaning
Dec 09, 2007 | Audio Players & Recorders
Replacement of body shell for 7373
well aparently the front clicks off with a screw driver, according to nokia, but i have not tried it yet, so dont blame me if it does not work. about the rest of the phone i have no idea..sorry!!!!
Oct 21, 2007 | Nokia 7373 Cellular Phone
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
70 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
