Question about Palm Treo 650 Handheld
Treo 650 screen brightness
MY screen is dim you still can see everything but if its dark out you cant. if i reset my phone(i've done a hard and soft reset) the i palm screen comes on and is as bright as can be but when software loads goes to dim.
    Problem Solver:
  • 8 Answers
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Posted on Dec 29, 2007
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
Tip
HOW TO PERFORM A HARD RESET ON Treo 650
Performing a hard reset on a Treo 650will erase everything on the smartphone. Most people do this because of trouble with the Treo 650's software. There are several key stages to performing a hard reset. Follow these steps to learn how to do it properly.
  1. HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
  2. Step 2 Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
  3. Step 3 Let go of the red phone button when you see the Palm screen.
  4. Step 4 Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
  5. Step 5 Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
  6. Step 6 HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
on Sep 17, 2009 | Palm Treo 650 Handheld
Phone frozen. Hard reset doesn't do anything
A hard reset will erase everything on the smart phone. If you still see your data, then you were not successful in performing the hard reset. In that case, what you have done is a soft reset.
Carefully try one of these two methods:
Main method:
1. Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
2. Push the up button on the five-way to start the reset process.
Alternate process:
1. Similar to the hard-reset of the Treo 650. Remove the battery cover.
2. Press and hold the Red radio button.
3. Use the stylus to depress the reset button next to the battery.
4. Push the up button on the five-way when you get a prompt to "Erase all data".
Aug 17, 2009 | Palm Treo 700w Smartphone
Language settings
Bueno, trata lo siguente:
If you purchased the Treo in the U.S., you should have the English to Spanish option when you reset the phone. Just make sure to back up your data before resetting it.
Step2Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset. Step 11Let go of the red phone button when you see the Palm screen. Step 2Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset. Step 3Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone. Step 4HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Do not forget to back up your data before performing the hard reset. If you don't, only the data from your last HotSync will be able to be recovered.
  • After performing a hard reset, install your applications one at a time to make sure each is in working order. Delete any applications that are not in working order, as those might have caused the need for the hard reset in the first place.
Buenas Suerte,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Joe Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 22, 2009 | Palm Treo 650 Handheld
Treo 650 phones turns off by itself
funny thing... the older palm treos like this one have some glitches. these glitches can normally be fixed by changing some of the settings.
1) go to your home screen, and select PREFS
2)select power
3) set your brightness level all the way to the right (NOTE: it takes more power to dim the screen then it does to brighten the screen.)
4) set auto off after: to the highest number allowed
please let me know if this helps!
Nov 25, 2008 | Palm Treo 650 Handheld
Keys don't work
www.ebay.com, I'm afraid. Unless, Have you done a hard, not just soft, reset?
http://search.active.palm.com/?q=hard+reset+palm&x=0&y=0
Jun 04, 2008 | Palm Treo 650 Handheld
Treo 650 not able to access sim card
The SIM card is dirty or scratched.
Try taking the SIM out and wiping it with a dry cloth... then insert it back in firmly. If that does not work, you may need to replace the SIM card, or find a way to get it to press itself more firmly against the phone.
- J.
Feb 26, 2008 | Palm Treo 650 Handheld
Palm treo 650
You can do a soft reset by pressing the small indented button on the back with your stylus,: or you can do a hard reset by removing the battery and pressing the same button on the rear with your stylus. I would try the soft reset first, as the hard reset wipes all your data.
Jan 05, 2008 | Palm Treo 650 Handheld
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Palm Treo 650 Handheld Logo
195 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
