Question about Intel Motherboard
BUS WHAT IS THE FUNCTION OF THE BUS,& CO PROCESSOR IN MAIN BOARD,
Processor upgrade
WHERE IS THE QUESTION.
Feb 24, 2015 | Max Computers & Internet
Hi i would like to change my motherboards processor and ram. i would like to sync up with the boards front side bus speed and ram speed of the boards supports. my board is p4m800prov2. please send me the...
Please go to elitegroup website and download the manuel for your board it will tell you what processors?, what the bus speed is? what ram,? and how much you can put in! I hope this helps !
May 20, 2011 | EliteGroup P4M800PRO-M V2.0 Motherboard
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Toshiba L305-S5944 T 3400 Want to upgrade ???processor the bus speed is F/S bus speed is 667 can I break this Limit?? with a processor??? are is that it fast as it will go??? what does efect the board...
With laptops you are severely limited with what you can do regarding the processor. It's highly unlikely that you will break the 667 front side bus barrier at all. A laptop BIOS just doesn't support CPU overclocking and neither does a laptop motherboard.
The only thing you could do is upgrade the processor for a better one like a C2D T8100 for example but the bus speed on that is only 800 MHz so there are limitations.
A desktop motherboard is a different kettle of fish as some motherboards are designed with CPU overclocking in mind and are cheaper to purchase.
If you wanting to upgrade the processor for gaming purposes then i wouldn't bother as the GPU (graphics processing unit) in the L305 is not that good at all.
I hope i have answered your questions for you.
Regards.
Jan 24, 2010 | Computers & Internet
I have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
it support intel 478 pin processor 1.8 ghz 400 bus up to 2.4 ghz 533 BUS
May 29, 2009 | Intel D845GVSR Motherboard
Hav K7T266 Pro2 motherboard, can not get it to go past turning on
Lorna,
to change bus to 133 MHz, you need to unlock the speed by setting a corresponding jumper on the board to assign busspeed by bios. After doing so, you need to clear CMOS and reboot. Next you'll have to set speed and multiplier in bios. Ideally: 900MHz = 100 x 9. Alternatively: 133 x 6.5 If that doesn't help...check if your RAM-modules are any good anymore. When RAM is not functioning, CPU-error code may be presented, since CPU cannot read/write to RAM, therefore not function. Let me know how this turns out.
Kind regards,
Stephan
Jan 30, 2009 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Devices problem
Hi!
It's good to hear that the sound problem is already fixed. You did a good job!
Regarding the co-processor and bus SM control with a yellow question mark (?) , the truth is I have no idea what specific device it pertains to. However , we can isolate what it is by knowing what specific features in your laptop that does not function well or does not function at all.
Did you notice any feature in your laptop that does not work well or doesn't work at all? Look for features such as card reader, USB port , or if there is any button on the laptop that no longer functions. If one of these laptop features doesn't work , then chances are the they are the devices with the yellow ?. You will have to download the drivers for each and install them manually.
The key here is to download the drivers that we need. Unfortunately, we do not know exactly what file to download. What you can do is to go back to the site where you downloaded the driver for your audio device, download all possible drivers that you can (this is time consuming but you may need the drivers in the future anyway).
After downloading the drivers, go back to Device Manger and right click the device with a yellow question mark , select Update driver and follow again the same steps I already posted in updating the driver manually.
I hope that helps.
Good luck and I hope to hear from you again.
Nov 20, 2008 | Compaq Computers & Internet
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
New graphics card needed
If your looking for a fast graphics card u will be limited to mostly 256 mb nvidia chipsets.
lots to choose from. go to www.tigerdirect.com
Oct 05, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Processor
What type of chipsetup your motherboard has and up to what bus speed its supports, what processor speed now u use and what model is your server, most server main boards supports two processors please lets us know what model server u got
Jun 27, 2008 | Gateway 920 Series (gtwy920) Server
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
