Question about LG LDF6810 Built-in Dishwasher
Lg built-in dishwasher
Shows error LE WHAT DOES THAT MEAN...many people complaining the motor, or the pump needs replaced. this unit is only 5 months old!
  • Anonymous Jan 02, 2008
    Getting LE error in 3 mins after start. Machine purchased in Dec 2006. Was told to flip breaker or unplug for 30 minutes and this should clear. This does not work
  • Anonymous Dec 27, 2008
    After a few mintues le comes on and the dishwasher stops working.
I had a break in the purple wire, in the door panel. Wires were imbedded in black insulation. Spliced wire and inserted plastic between all wires and black insulation.
Thank you
Posted on Nov 26, 2008
I just solved a LE error code on my dishwasher,,,,it was a broken wire caused from the black sound deadening material LG uses...apparently when the dishwasher heats up the black stuff becomes soft...wires become imbedded then when it cools and you open the door it breaks wires...easy solution...soldered wire, put a thin piece of plastic to where the wires couldnt get imbedded , put back together and works great
Posted on Jun 04, 2008
I'd like to list a solution for this problem. i'll never buy an lg product again. both the stove and dishwasher have broken down! they are brand new! i am now waiting for the repairman to fix the dishwasher for the second time! oh boy, if it breaks again, they will replace it for free! lucky me, they will replace it with the same piece of crap!
Posted on Feb 26, 2008
  • 92 Answers
LE is locked motor or break in the wire to the motor if under warranty call for service as there is a problem with the noise insulation (in the door) deterioration the coating of wires and causing any kind of failure.
Posted on Feb 10, 2008
Our dishwasher shows an LE error code when started. What is wrong.?
Le error is a motor error. either there is something lodged in the pump holding the blades or the motor itself needs to be replaced
Jun 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
I'm getting a code "LE".
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
Sep 26, 2009 | LG LDF6810ST Stainless Steel Built-in...
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
LG DISHWASHER, STOPS WORKING AND DISPLAYS LE. WHAT DOES THIS MEAN
LE is a Motor error
Sep 07, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LE error code
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
Jun 21, 2009 | LG LDF6810 Built-in Dishwasher
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
Mar 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810 Built-in Dishwasher Logo
285 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
