1999 Acura TL. Message is: Hard disk reading error (unformatted) Please consult your dealer
Is there a way to repair?
You can buy a replacement at www.navhelp.com
SOURCE: Replacing HID headlight in 2004 Acura TL
HID Bulb Replacement
A transient high tension (25,000 V ) occurs at the bulb sockets of the high intensity discharge (HID) lamps when the combination light switch is turned ON, it may cause serious electrical shock or electrocution if you do not observe the cautions below.
CAUTION:
SOURCE: How do you reset the check engine light on an Acura TL 1999
i dont know how else to do it other than with a diagnostic tester. i think that may be the only way.
SOURCE: Disc read error on my 2005 acura TL gps
Was the door open when you got the message (easy to do)?
Did you close the door properly?
Did you replace the disc shiny side down?
SOURCE: I want to replace the low beam bulbs for 1999
just did it tke a breath and put on your small hands!If you r talking about hid bulbs i found aftermarket bulbs at www.moble-emotions.com its best to get both and change them togetherso they match i did only one first and you could see the differance big time.On the battery side the black cover to lightbulb neens to b poped off there r two thumb push tab pry light with a screw driver. on pass side take the 10mm bolt off washerbottle and move aside.(.you need a small hex or starbit to remove the set screw.after u get the set screw off takr both hans and twist hard the cover has a slot as u turn off pull out.there is a hook tab about the size of a paperclip un hook at bottom bulb its fixed at top so just lift bottom to top.remove and replace bulb.(twist out )reverse stepsI also looked at a picture on acurra parts site goood luck i think i did it better than discribing
Testimonial: "thanks, your direction was very helpful..."
SOURCE: can i get to fuel pump on 1999 Acura TL from back
Below are the proper steps to removing your vehicle's fuel tank..
Disconnect the negative battery cable.
Relieve the fuel pressure
Remove the rear seat cushion.
Remove the plastic grommet from the floor pan.
Detach the fuel pump
electrical harness.
Disconnect the fuel lines from the fuel pump by compressing the tabs on both sides of each nylon push connect fitting and easing the fuel line off of the fuel pump.
Raise and safely support the vehicle securely on jackstands.
Remove the muffler mount.
Remove the heat shields.
Remove the fuel tank cover.
Remove the drain plug and drain the gasoline into a approved container.
Disconnect the fuel lines and remove the fuel filter and base.
Loosen the fuel tank filler pipe clamp at the fuel tank.
Support the fuel tank using a hydraulic jack and a block of wood or other suitable device.
Remove the two fuel tank support strap bolts and position the straps out of the way.
Partially lower the fuel tank to access the fuel tank filler pipe vent tube and disconnect the vent tube and filler pipe from the tank.
Disconnect the fuel vapor tube from the tank.
Lower the tank from the vehicle.
Installation is the reverse of the removal procedure.
