Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
Signal strenght just gone!
I have three laptops at home, two of em' running with vista :( and the last one, a classic, running with XP SP2, the vista ones have no problem to connect to the wireless network, but I tried using my 2wire 802.11 wireless card and got No Signal at all, it shows the network, it says it's in range, but no signal, and obviously is unable to connect, I tried changing the scurity settings but nothing seems to work. can someone help me with that little problem? my router is a Dlink DIR 615, which is good enough for three computers in a small house.
  • alpinito Dec 29, 2007
    The Security is Okay, Im using WEP and using the key properly, and by the way, I have High speed Internet (10 Mbps / 4.6 Mbps tested) thanks again
  • Anonymous Jan 06, 2008
    need drivers
    Genius:
  • 1,601 Answers
Are you using the same security as the others?
Make sure the the security key is exactly the same as the others.
Also check the firewall settings
Posted on Dec 29, 2007
  • Thomas Christopher
    Thomas Christopher Dec 29, 2007
    Check the device manager and see if it looks good there.
Hay! my laptop is toshiba satellite A135 s4527 home vista. but i run my laptop with oprating system windows XP2. how it possible. please help me
Hello and welcome to fixya.
In your case, im assuming you refer to the "Vista sticker" that is on the laptop. If a computer is vista-compatible this doesn't mean that it is not able to run older Operating Systems (such as Windows XP SP2) as well.
The sticker on the laptop just referes to the type of Operating System that came pre-installed with it. Now if you bought the laptop and asked your salesman for a DOWNGRADE TO XP Operating System or if this is what he understood then it will probably come with Windows XP instead of Vista Home.
This also applies if you are working for a company in which case the company's IT Department will decide what type of Operating System is to be installed on this computer.
Overall: Newer computers/laptop models that support Windows Vista can also run Windows XP
ALSO: Check for the OEM sticker in the back of the laptop or bottom (it looks like THIS for XP or THIS for windows vista Home Premium). This determines whether you can use a vista DVD to upgrade your computer later from XP to Vista.
If you have any more questions just let me know.
Thanks
Regards from FixYa.com
Apr 13, 2011 | Computers & Internet
Windows is showing a remove hardware icon. when I click on it, it wants to remove the cd/dvd..name is hl-dt-st rw/dvd gcc t10n. I've tried disabling the driver and restoring it, disabling device and...
Operating System Windows Vista™ Ultimate, Windows Vista™ Business,
Windows Vista™ Home Basic,
Windows® XP Professional SP2, Microsoft® Windows® XP Home SP2, FreeDOS
Try formatting your windows into windows vista or windows 7. It might solve you problem.
Nov 25, 2010 | Dell Latitude D630 PC Notebook
I unable to install Xp in my compaq cq61-132tu. The install option just doesn't get highlighted. Also, i don't have another computer.
I assume you are attempting a "downgrade" to Xp from Vista, since this laptop does not come with XP.
From the Compaq information page:
  1. HP does NOT support XP for consumer notebooks, so if you have any difficulties regarding XP, do not expect HP will help you.
  2. HP may demand you to install back VISTA if you have hardware problem to troubleshoot it.
    An option to consider-put your original Vista hdd away and install new one for XP.
  3. Some of the notebook features may not work in XP due to uncertified licenses pointed in this guide.
  4. Microsoft has released three (3) Service Packs for XP, use only SP2 for the first trial. Why? Since many of XP drivers are released based on XP-SP2.
  5. Always make Vista Recovery cd/dvd before downgrade to XP. see it here
  6. You have a folder with drivers & programs that may prove very helpful after XP downgrade.
    Copy folder C:\Swsetup to DVD Before formatting your hdd.
  7. If you have a pre-SP2 XP cd, get the full SP to Integrate with Nlite: SP2 Nlite HERE
The help guide for downgrading is here. There is a lot of information on this process written there.
However, if what you want is a an XP look and feel so you can compute the way you used to, change the Vista to look like XP in the display properties.
If you are trying to run non-Vista software, try running it in compatibility mode. To do this, right click on the program files and select properties and then locate compatibility..
Jan 04, 2010 | HP Presario CQ60-204NR PC Notebook
Problem connecting to WNR2000 on laptop running vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 26, 2009 | NetGear WNR2000 Wireless Router
How i can install xp sp2?
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from www.download .com
May 09, 2009 | Computers & Internet
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Load XP in Dell inspirion 1525
If U want to change ur pc's os to WinXp the go to dell.com and choose Ur country after that go click on the support link or support and driver link then choose ur laptop after that choose the operating combo box to winxp(sp2) and if there is driver's are available or not in most cases Every Dell laptop has xp(sp2) drivers............
Shubham.................
Jul 26, 2008 | Computers & Internet
Sm bus controller drivers
you have to install the sound drivers from the mother board cd
Jun 24, 2008 | Toshiba Satellite A105 Notebook
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
114 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
