Samsung LE40R74BDX 40 in. LCD Television
Problem for Samsung LE40R74BDX 40 in. LCD Television
I get a ghosting effect or delay in movement when
By martinp_gill on Oct 19, 2009
I get a ghosting effect or delay in movement when watching cable but not through arial on my LE40R8
Watching cricket looks like the bowler has ten arms !!
Solution #1
posted on Oct 27, 2009
Not Rated)
Chu3505
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 85%, 527 votes
Ur main video backlight board it dead,u can tries with other tv see if same prob.i doubted it cable signal.
Was this helpful?
Yes
No
Solution #2
posted on Oct 19, 2009
Not Rated)
CABLE_GUY_10
Rank: Wiz
Rating: 90%, 17 votes
ghosting is caused by ingress, or interference, getting into the cable signal. make sure all of your cable connections are tight. if this doesn't fix the problem, contact your cable provider, as the problem may be outside the house.
Was this helpful?
Yes
No
Popular Solutions for Samsung LE40R74BDX 40 in. LCD
Questions and Unsolved Problems for Samsung LE40R74BDX 40 in. LCD
Do you recommend Samsung LE40R74BDX 40 in. LCD Television?
Answer
Answer
When i switch on the tv the volume goes instantly to maximum 100 and won't work via the tv controls... (More)
Answer
cant remove the stand to wall mount the tv its a evotel elcd32usb
Answer
hi i am trying to put on the stand on the samsung le40b650 can you help as the platic clips look... (More)
Answer
cant separate the lucite neck of the base from the monitor on the p2370 monitor to send it back in... (More)
Answer
I have just bought a 40" samsung LCD tv and the TV channel doesnt work. I think maybe I have to... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
