Question about Stoves Broan 40000 Series Hood - 36" Hood (ABE403601)
Eco45 pellet stove
Stuck in manual mode and on 3rd high setting - won't reset and flashing H and then 1
won't reset
  • slick64 Jan 27, 2008
    same thing here... did you solve yours?
  • jhayes6843 May 03, 2009
    My Braun hood fan has a continuous humming & the fan is turning. I'm afraid that it will over heat. I have turned the breaker on & off in hopes that would reset it but no luck. Help.
Try unplugging it then plug it back in if that dont work most of the time its cheaper to replace hood vent than repair
Posted on Dec 29, 2007
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' ... > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
What is causing the ready light to flash red twice when I try to light my pellet stove
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
What are the pros and cons of operating the Quadrafire Mt Vernon AE pellet stove in manual mode?
They probably cannot suggest running it on 'manual' due to liability reasons....leaving home for an extended time and forgetting its on manual...comes to mind.
What may be suggested is to make sure ANY and ALL safety controls still function to shut off fuel (pellet) flow in the manual mode as an extended overtemp condition is the first thing that comes to mind when you think of damage to a heating system or to the structure within which it is installed.
I think its a judgement call on your part once you determine you pretty well KNOW the full and complete operation of the device. The key to that statement is KNOWING WITHOUT A DOUBT the FULL operation of the system.
I also would NEVER recommend to a customer to operate it in the manual position.
Mar 25, 2015 | Heating & Cooling
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
Auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Jul 08, 2009 | Napoleon Auburn Pellet Stove Heater
Purchased a used Earth stove mp240 pellet stove and the auger does not move. we are looking for a manual or information on this stove it is an older stove we just don't know how old. Thank You
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Jun 10, 2009 | Napoleon Auburn Pellet Stove Heater
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Jan 16, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
Sep 30, 2007 | Stoves Broan 40000 Series Hood - 36" Hood...
Kitchen Ranges Logo
472 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
