Drain the water out of the neptune front load washer machine
Do you own a wet/dry shop vac? An easy option is to pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will clear any residual water from the wash tub and drain lines without the mess. I hope this helps you.
Take off the back panel
two 1/4 in screws
just inside you will see the pump
remove either of the two hose and the entire machine will drain...
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
