Problem with capacitor of air conditioner?
The compressor of my air conditioner (Samsung AW24F1MBC 24000 btu/h) is trying to kick on but it can't start. I suspect of the capacitor but it have not specification (erased?).
I need this specification or a detailed circuit diagram.
  • Claudio Bustos
    Claudio Bustos Jan 10, 2008
    Hi again, i downloaded the parts list of this model and similars and found the magic number: 45mF. It's working fine.
The ratings of the capacitor should be on the capacitor itself in mfu sounds to me like the compressor stuck and cycling on overload is the capacitor distorted or swollen
Posted on Dec 29, 2007
I have a 5,000 btu frigidaire a/c and the compressor won't kick in
Could be the starter contactor, the capacitor or the compressor by itself . You can see the condition of the starter and maybe clean or if it looks bad , must be replaced. The same goes for the capacitor if the compressor is humming. But if the compressor motor is not starting up , please check for starting current with a clamp tester, if it goes higher and stalls then the compressor/motor is faulty.
Might need help to do an overhauling.
I hope this advice helps.
Aug 20, 2010 | Frigidaire FAX052P7 Compact Room Air...
I have a whirlpool 24500 btu air conditioner it
It sounds like the thermostat sensing bulb is not sensing indoor air temperature?
Jun 07, 2010 | Heating & Cooling
Size of air condition.
Get the cubic volume of the room. The highest temprature differential. and how many air changes you need. this will give you the btu required.
If this is too high, get the biggest unit that your supply can safely carry.
Mar 27, 2010 | Samsung AW1091L 10,800 BTU Air Conditioner...
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Jul 23, 2008 | Dometic Rooftop RV Air Conditioner
Have a hampton bay 24000 BTU AC. Smelled burnig behind control panal. Opened it up found what seems to be an overload switch burnt through.. Leads go to capacitor terminal C & Herm. I changed the...
I checked wiring on my other 17,000 BTU Hampton bay AC & noted there was no overload switch wired into capacitor. So i just removed the burnt out overload switch which was causing a ground & blowing breaker. I noted it was not wired in between the compressor circuit but just attached to the compressor terminal & common terminal on capacitor. I guess it is a sacrafise type device that saves the compressor from burning out on overload. Anyway The AC worked fine with the burnt overload switch removed. It has been runnning 2 days now with no problems. I however did replace the capacitor with a new one. You can use either an oval or round capacitor as there is ample room. Just make sure your cap. values match old one. I will probable try & purchase a new overload switch if possable & install it at a later date, for the extra protection.
Angelo V.
Jul 20, 2008 | Hampton Bay Heating & Cooling
Haier Air Conditioner (24000 BTU, 240 electric)
The compressor is probably bad. This is what some do when they are failing. The compressor is the heart of the unit and very costly to have replaced. Only a licensed technician can do this for you. The EPA regulates the refrigerants used to complete this job. In most cases it is cheaper to simply replace the unit then to fix it. If it is new I suggest exchanging it for another one on warranty.
Jul 08, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
472 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
