Question about Microsoft Xbox 360 Console
Does not read disc sometimes reads them as dvd
New xbox 360 played ok for one day and then would not read discs and sometimes only reads them as dvds
  • 1 more comment
  • Anonymous Dec 29, 2007
    My xbox360 reads disks as dvds.
    i put my 360 game in and sometimes it reads as a dvd
  • DarkHeretic Jun 25, 2008
    I also had the same problem but so far it's only happened with a rented copy of Kane and Lynch: Dead Men. The weird thing is that it was working fine only ten hours before I experienced this problem. I put the disc in and it only reads it as a DVD. When I try to play it I get a weird error message. I've tried cleaning the disc and I shut the Xbox 360 on and off a couple times, but this still happens and it only happens with this game. It could be the Xbox 360's lens possibly, but could there be a scratch on the disk that would cause the Xbox to read it as a DVD?
    New Friend:
  • 127 Answers
If the disks are old they wont work, or the disks are for the old xbox console.
Posted on Dec 29, 2007
My xbox wont read any discs
Maybe1)The Xbox 360 does not recognize a disc in the DVD drive
2)Disc is "unreadable" to the Xbox 360
3)DVD drive tray will not respond or move
Every issue has its own unique cause. A disc with scratches could be an issue. You should have no problems getting this issue fixed. See if another disc does the same thing.
It most likely says "Unable to read disc" because it probably can't read the disc! If I were you, I would try cleaning off the disc you are using, then putting it back into theXbox 360 and try again. It may also be scratched repetitively, which cannot be fixed and you may need to buy a new copy of the disc.The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
Feb 20, 2011 | Microsoft Xbox 360 Console
Xbox 360 will not read games or dvd's
Try to insert a straighten paper pin into the hole under the tray if still no go You have to open the cover and take the cd out.
Sep 01, 2008 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts:
DVD Drive Swap Info:
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Xbox restarting, DVD drive won't eject or read discs after
No, your motherboard and DVD drives have to match.
Feb 27, 2009 | Microsoft Xbox 360 Console
Will not play games
Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
Jan 31, 2009 | Microsoft Xbox 360 Console
Will not play a game
this usually happens to bad/damaged/dirty game disks. try cleaning the disks. if that doesn't work, contact microsoft via
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Dec 27, 2008 | Microsoft Xbox 360 Console
Unplayable disc
have you tried cleaning your Disc.
Jul 16, 2008 | Microsoft Xbox 360 Console
Brand New XBox 360 will not read discs of any sort
phone ms, or you got an expensive paperweight
Oct 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
67 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
