Question about Amana ARB2217C Bottom Freezer Refrigerator
Amana ARB2217C Fridge
My refrigerator has a common problem. The freezer compartment is cold but not the fridge compartment. I notice the freezer compartment has a lot of ice built up. Can you let me know where I can find the defrost timer in this refrigerator? I have hard time to locate this device. Thank you.
  • btang Dec 31, 2007
    Great and fast response. Thank you.
  • Anonymous Apr 03, 2009
    The freezer is cold but the fridge is warm...won't run even when the thermostat is turned to coldest setting.
Its under the light bulb assembly in the frigidare compartment
Posted on Dec 29, 2007
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Jun 27, 2011 | Amana Refrigerators
The freezer seems to be working but the fridge doesnt seem to be getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Jan 04, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana fridge
is the freezer cold. the freezer is acualy the only refrigeratted compartment . it has the evap coil in the rear wall and a fan to cerculate the air . a potion of the air is let into the food compartment . most comonly the freezer defrost system can be the fault. so i would requier answers to the first question. is the freezer compartment working. hope this helped
Oct 19, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Botom freezer working fine
Could be, also, maybe the drain hose may be kinked or plugged. Normally the hose leads to a drain pan under the ref, where a fan blows across it to evaporate the water.
Aug 08, 2008 | Amana ARB2217C Bottom Freezer Refrigerator
Amana ARB2217C Bottom Freezer Refrigerator Logo
257 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
