Sharp AL-1655CS Laser Printer
Problem for Sharp AL-1655CS Laser Printer
My Sharp AL-1655CS copier has new drum and toner.
By t_daniels924 on Oct 19, 2009
My Sharp AL-1655CS copier has new drum and toner. Leaves blank banding lines verticaly down the page in at least three areas.
Solution #1
posted on Oct 19, 2009
Not Rated)
dwaindobbs
Rank: Guru
Rating: 87%, 33 votes
This is a good one you may need to get it serviced.
The toner is held to the drum by static which rolls the toner onto the paper and seals the deal you may have a bunk drum, Validate your warranty and check for a service center.
Was this helpful?
Yes
No
Popular Solutions for Sharp AL-1655CS Laser Printer
Questions and Unsolved Problems for Sharp AL-1655CS Laser Printer
Do you recommend Sharp AL-1655CS Laser Printer?
Answer
Answer
como faco para instalar o scanner sharp al 1655
Answer
Need 64 bit driver for AL-1651CS for vista/win7
Answer
I am attempting to install the drivers for the Sharp AL-1655CS printer that is connected via the... (More)
Answer
Printer is making a loud grinding noise and will not print anything. Readout flashes system error... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL-1655CS Laser Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
