Question about Durabrand DVD-1002 DVD Player
How to shut off closed caption on my dvd
I have the remote but cant figure out how to get theclosed caption off my screen
  • Anonymous Jan 16, 2009
    I know 2 with the same problem, and the subtitles will turn themselves on regardless...
  • Avidan Feb 12, 2009
    I too have this issue.
    The solution of turning off the caption only works when it lets you. Most of the time, turning off the caption gives you the little yellow hand meaning "No" or "Can't Do".
    It's a great little DVD player and for $20 I'm not really going to quibble, but just throwing in my two cents that I have the same problem.
    A.
There is a "subtitle" button to the right of the "3" button. Press that until it says subtitle or caption off.
Posted on Dec 30, 2007
I cant turn off the closed caption...the cc button on the remote does nothing at all and the menu option for advanced closed caption says off but its still on.
Are you watching a DVD or the TV? If you are watching the DVD you may have to turn off Closed Captioning on the DVD. To do this go to the main menu of the DVD and look for Closed Captioning under options. Turn that off.
Apr 20, 2016 | Televison & Video
How do i turn off the closed captioning setting on my 27
Hello
Without its orginal remote, you can't turn OFF its close caption window.
If you ahve its original remote control, inform me by Fixya comment. I'll assist you to turn off this option. Without orginal remote control, giving any advice to you to rectify this problem, will be waste of time.
Feb 18, 2012 | JVC AV-27D303 27" TV
Black box popping up on screen
Your closed caption is turned on. The box is a text box. Closed captioning has CC1, CC2, CC3, CC4, TEXT1, TEXT2, TEXT3 AND TEXT4 modes. Each mode has it's own use or screen position. If you have a CC button on your remote, press it until CC is OFF. You may need to go into the TV menu to do this, I'm not certain. At any rate, with a little investigation, you should find the closed captioning feature and discover how to shut it off. Best wishes.
Apr 16, 2010 | Olevia LT42HVi 42 in. LCD Television
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
May 17, 2009 | Sanyo DS31520 31" TV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Nov 27, 2008 | RCA TruFlat 27F520T 27" TV
Closed caption isn't shutting off!
Do you have the original remote? Just press "c.c" three times to close caption - off. Hopefully you have solved the problem already.
Aug 02, 2008 | JVC AV-27D302 27" TV
Closed Captioning
Turn your DVD player on with no disc inside. Use your remote and press the Setup button. From there go to audio and there should be some settings for closed captioning.
Dec 26, 2007 | Toshiba SD-V392 DVD Player/VCR
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Durabrand DVD-1002 DVD Player Logo
366 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
