Question about Microsoft Windows XP Home Edition
Windows xp will not install
I have a computer i am not sure of what computer it is but i also have a windows xp recovery cd and i had to put a new hdd in it and tried to install windows vista but it would not load properly so i tried booting from the windows xp cd and it comes up with boot from cd but then it just loads past that so i created recovery cds on an emachines 4260uk and then loaded it onto the other computer and it created a recovery partition on the new hdd and then i went through the recovery procces and then after it had finished the recovery procces it restarted and just went to a black screen after loadin from the bios but i also tryd the windows xp cd on my emachines that works and it will not boot from it but when i put it in with windows running it loads fine and works fine i have checked all the cd drives and they work fine but i cant boot from cd still can you help me please
  • 1 more comment
  • ashley hunter Oct 20, 2009
    i already have it vomes up with boot from cd and then it just loads even when i press any key
    no i want to install windows xp because windows vista keeps corrupting after the installs
  • anthar May 11, 2010
    sorry i dont get it clear, do you want to install vista os on your pc? if so please make sure your pc spec. passed windows vista requirements
    Scholar:
  • 84 Answers
If you don't see the message on start up "Press any key to boot from cd" Then you need to change the boot order.
Start the PC and hit delete a number of times. This will take you into the bios screen. (Set up screen)
You will have a tab called "Boot Priority" or "Boot order". Make sure that CD/DVD drive has 1st priority. Save & exit & your done. Upon restart if you have a disc in the drive you will get the option to press any key to boot from CD/DVD. By default, most motherboards are set to boot from floppy & then Hard drive so in most cases you will need to enter setup & change the boot order.
Don't forget to rate me.
Posted on Oct 19, 2009
SOURCE:
Hp compaq 530usdt windows\system32\conf\system. File missing or corrupt
insert original win installation cd and reboot... when in boot mode make sure you are booting from CD, not from disk, when message asking that you "boot up from cd " appears, just press any key, and folow procedure, but do not install a new copy of windows ! There must be "repair your computer" option on your CD, for Win Xp - it is "recovery console" ! When repairing finishes restart computer and boot from disk (just do not press anything when you see message "boot from CD..." and let windows from HDD configure it self).
Mar 10, 2014 | Computers & Internet
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
I'm trying to reinstall XP on my sisters viewsonic V1250s and I cant get it to load. I have the recovery cd's and an external cd drive. Her roomate put linux on it and jacked it up. I put in a new HDD and...
> check the disk
Check for scratches on the media.
Also, it could be "bad" RAM in the computer that is creating "random" problems, which could be reported by the B.S.O.D.
If the computer has multiple sticks of RAM, remove one, and try again.
Nov 13, 2009 | ViewSonic Tablet PC V1100
After installing new Biostar Motherboard (MCP6P-M2+), Windows XP won't start
You may need to check your bios settings and make sure the proper hard drive is set to be booted. If it is, follow the next set of instructions.
Windows " tailors " itself to the hardware it's connected to when installed. An easy fix is to repair your XP install like thus:
boot the PC from the XP installation disk
DO NOT select recovery console if prompted, instead continue installation
when XP searches your HDD it will find your previous install of XP, when it does, it will ask you if you wish to install, or repaire, select repaire...
it will seem as if XP is being re-installed, infact it is, but it will retain your files, and programs.
Once completed, your computer should boot properly.
Nov 02, 2009 | Computers & Internet
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
1. Boot the computer using the XP CD. You may need to change the boot order in the
system BIOS so the CD boots before the hard drive. Check your system documentation
for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery
Console, press R", (you Do Not want to load Recovery Console). I
repeat, do not choose "To repair a Windows XP installation using the
Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows
installations.
5. Select the XP installation you want to repair from the list and press R to start the
repair. If Repair is not one of the options, END setup. After the reboot read
Warning
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any
key to boot from CD when the message appears. Setup will continue as if it
were doing a clean install, but your applications and settings will remain intact.
Apr 05, 2009 | Computers & Internet
Network Boot Windows XP?
Put the HDD in any other computer , creat a folder called XPbackup and copy the XP cd to the folder, Start the XP install from the other computer  , when the install stops for CD key , turn of the computer and remove the HDD and put the HDD on the laptop and turn it on , Mostly the installation should start from where it stoped. If the Xp install askes for the source files , browse to the folder created and point to the files. Most of the time XP will install a generic HAL so no need to worry.
Mar 09, 2009 | Microsoft Windows XP Professional for PC
Upgrading HDD From 40GB To 160 GB
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Microsoft Windows XP Home Edition Logo
112 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
