Question about Toshiba Satellite R10-S802TD Tablet PC
Satellite A45 S150
When power is plugged in, computer will not turn on. Power light is blinking yellow. What do I do?
    President:
  • 4,402 Answers
Hold it down for 10 sec.
if that doesn't work remove battery and try again
Posted on Jan 15, 2008
  • CHAD LAHTI
    CHAD LAHTI Oct 12, 2013
    do u get any display during rebooting? try hooking it to an exterior monitor..if still no display ./. make sure ur ram is seated still..if u still get no boot dispaly ... u got big problems..
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
I have a toshiba tecra m4-s435. i plug it in to try to use it and the charging light just blinks i got a 12311 error code off it but i cant find the code anywhere to help me with this problem. i asked...
Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer.
If you report that to the Toshiba Technical personnel, they can transcribe the error number for you.
If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
Jan 11, 2018 | Toshiba Tecra M4-S435 Tablet PC
My kindle will not turn off. I can't get it to do anything.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still doesn't respond, do a hard reset by holding the power switch for 15 seconds
Jan 27, 2011 | Amazon Kindle Wireless Reading Device
My kindle does not to turn on when i slide the power switch
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 22, 2011 | Amazon Kindle 3G
Kindle 3g screen is blank can get it back on
Jan 17, 2011 | Amazon Kindle Wireless Reading Device
I have a Kindle DX. I turned it on today and it has a black page. How do I get it back to normal?
Dec 28, 2010 | Amazon Kindle DX
My Kindle is turned on ( i cant tell as my lighted cover light comes on) however the screen is still blank. What can i do to fix this? Thanks!!
Oct 24, 2010 | Amazon Kindle Wireless Reading Device
My Portege M400 will not turn on with the battery installed. It will work if you remove the battery and use the power supply. The power light only blinks yellow while the battery is installed. I have tried...
You look very much the unlucky owner of a busted battery.
I'm afraid the battery will have to be replaced. Meanwhile, do not use it with the power supply; not only it will do no good, as you already determined, but it might damage the power supply itself.
Jan 03, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba satelite r15-s822 will not power up
Take the battery out and try starting it with just the power cord plugged in.
Sep 25, 2008 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
134 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
