Flat sreen screen is fuzy on all inputs sometimes it goes out but still have sound
    Genius:
  • 1,139 Answers
Hello toyboy94,
I am going to assume that you have a flat screen CRT type unit the utilizes an Integrated High Voltage Transformer which uses a focus block (either internal or external to the transformer). Now by making this assumption, This makes your problem one of the focus block or the IHVT going bad. In order to check this problem I would use a high voltage probe to check the voltage on the anode of the CRT (20KV - 30KV) is expected. Once the anode voltage is checked look at the schematic to determine if the voltages are correct. If the voltage is not correct then check the voltages being supplied to the transformer and compare them to the schematic values, once this is done what you should begin to see is differences in the voltages in the set vs what is shown on the schematic. I would take a guess and say that the problem might be one of a bad focus block since that would cause the symptom you are seeing, but nothing beats troubleshooting the problem. if the IHVT is bad get the part number and order the part then replace it. You will need to have a voltage meter, an ohmmeter, an oscilloscope, a CRT analyzer, and a High voltage probe to troubleshoot this issue. If you do not know what these pieces of equipment are and what they do, I would advise calling your local TV shop and having them look at the set and determine the proper course of action, If you do know how to use these tools, the repair should go quite easy.
I hope this helps,
Thank you,
Shuttle83
Posted on Dec 29, 2007
I'm trying to set up my Panasonic smart viera as650 the picture quality isn't as good as it should be its fuzy around the edges of words and when footballs on things that move fast seem to have a slur to...
Check the anti-judder settings and also the viewing mode (Cinema, Sports, Game?) and refresh rate in the TV setup options. Depending on the source input and resolution, the anti-judder settings can actually make screen motions worse and blurry.
Feb 12, 2015 | Panasonic Televison & Video
55"sharp aquos led flat sreen and its making a
Can it be heard with sound off and describe the sound a bit, buzz or high pitched sound? Not unusual for the front screen unit to make a slight buzz but I gather this is loud.
Dec 13, 2012 | Televison & Video
Sometimes tv sreen comes on then goes black, in the right lighting you can see the barely see the picture, other times the screen wont come on. either cse the sound works fine
Sounds like the backlight or backlight inverter is out on your TV.
You will likely want a seasoned professional to repair this for you assuming the TV is out of warranty.
Sep 05, 2011 | Samsung LN-S4051D 40 in. LCD Television
Sreen comes on for a second and then goes off
hi there.it sounds like the inverter board is faulty.its the pcb which lights up the cold cathode lamps behind the screen.readily available on ebay usually.relatively easy to fit yourself! (depending on the model,that is!!)regards,steve
Jul 31, 2011 | Philips Televison & Video
LG 37LF75 LCD SOUND NO PICTURE SOMETIMES CAN GET INPUT TO COME UP AND GET IT ON HDMI ONCE YOU PRESS OK AFTER 2SECONDS SCREEN GOES BLACK
I have a LG 37LF75 that the picture has stretched hoizontally eg; wording at left or right of the screen is slightly off screen in all ratio settings. How do I adjust the picture horizontally?
Sep 07, 2010 | Televison & Video
Red fuzy screen
You had not fixed all connector properly.
Jan 23, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
My sreen is fickering all the time,so bad sometimes the screen goes black,
Sounds like you need a screen replacement. The bulb that provides the backlight to the screen is going / gone bad.
Jan 07, 2010 | HP Pavilion dv9000z Notebook
Console freezing in main menu after a min green and red dots
do not perform fan test not good for unit. use vacume to clean out unit. if it was the motherboard it wouldnt turn on at all.
Jun 01, 2009 | Sony PlayStation® 3 (60 GB) Console
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
