Question about FIC AM 35 Motherboard
Emachines w1500 video problems
I have a computer that I am trying to fix for a friend, his wife decided to clean it and well now I have it to fix, here is the problems that I am running across, it will power up just fine and it sounds like it is accessing the hard drive but I have no video output, I have replace the Ram with brand new, I have put in a new video card thinking that is what the problem still no luck, I have read a few posts on here about a reset button but never found on under the battery like it suggests, I am really new at this and dont know what a jumper is to try to do what someone mentioned on here, all I know is that it is not beeping like someone mentioned and other then that it sounds like it is running fine but can not find a reason as to why it is not displaying anything, when a monitor is connected it is stating that the monitor is going into a sleep mode, I have considered replacing the mother board but I cants say that i am a genious in that catagory either, I would not know how to make sure that it has the right bios and things of that nature, I am sure that I dont know even half enough to scratch the surface as to what you people on here know about this kind of problem so I really would appricate any help that I can get thanks for taking the time to read this post thanks again
  • nullmedic25 Dec 29, 2007
    thank you for trying to help but I did it step by step and it didnt help thanks again for your time and effort.
  • 4 Answers
Ok, First remove the memory you install in. Then take of cmos battery for a couple of minutes. Then replace it.memory too. Make sure you do not power cable on for computer.
Listen this: turn off monitor. turn off desktop and remove all power cables from outlet. First connected monitor cable to computer then plug it to outlet. then connected desktop and turn on. when computer powers on press and hold F8 see if you can see safe mode. Then as me again.
Posted on Dec 29, 2007
May be duplicate... I have 2 Denon cdr-w1500 recorders. They both started the same problem at the same time. I just cleaned them with q-tips and canned air (no q-tip fibers were left inside the units). ...
continuest uses of ant cd player or recorder will damage the eye. try 2 leave it upside down 4 a day 2 see if there is any dry spots in the eye. if not restart the cd player all day until it reboots
with a cd any kind. if unit is broken time for a dvd ,cd recorder/player. good luck buddy
Aug 24, 2014 | Denon CDR-W1500 2-Disc CD Recorder
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
My computer monitor has a green tint to it, can't seem to fix the color help
First, check your video cable. It should be securely connected to the computer (and monitor if not built in). If you can, try a new cable. Try the monitor on a different computer and the computer with a monitor that works on another computer. (This tests if the monitor or the video output is the issue.) Once you figure out where the failure is, you can decide whether to repair or replace the monitor, or deal with the video card.
I hope this helps.
(we had a monitor that went pink due to a loose vga cable. once we looked at the cable instead of the computer or monitor adjust buttons, the fix was easy.)
Feb 28, 2010 | eMachines T5274 Desktop PC
Dell computer, less than a year old, XP Pro, having problems freezing, especially when using applications like some browser-based games (my wife plays Happy Island and that stuff on Facebook), and also...
If your computer is less than a year old, you should be able to contact Dell technical support for help (support.dell.com)
It sounds like it's a driver issue - most likely video drivers. You can check the support website for updated drivers for your video card.
Jan 22, 2010 | eMachines T3604 PC Desktop
I have similar problem on an eMachines W1500
Thats your powersupply cable. look for a 4pin sloth on your mobo that looks kind of like that switch and plug it in
Jun 16, 2009 | E-Machines eMachines Desktop PC
E-machine computer not displaying anything on screen
Press F8 while booting and select Safe Mode to see if you can get video. If you do it could be a driver problem and you could uninstall the Display Driver in Device Manager and try to boot normally and look for an updated driver. Reboot into Safe Mode again and select Cancel if prompted to install drivers when restarting to avoid reinstalling the existing drivers if it fails to operate after doing so. If still having issues it could be a failing video card or motherboard if the video is integrated.
Dec 11, 2008 | E-Machines eMachines Desktop PC
EMachines T3830 PC Desktop - HOW TO INSTALL A VEDIO CARD
There are a couple of things it could be. From simply checking the cable on both ends (computer to monitor) to see if they are loose. It could also be the card is damaged. I would check it with a second monitor to be sure.
Oct 13, 2008 | E-Machines eMachines T3830 PC Desktop
EMachine monitor quit
This could be one of three components:
1. The video card
2. Video Cable (cable from the monitor to the computer)
3. The Monitor
The way I would determine this is:
I would try to plug this monitor into another computer that you know works with other monitor. If this is a home computer and you don't have another computer to test this take it to a friends house. Use a different cable to connect the to computer and power if possible. Then switch out to the old hardware (e.g. power cable, video cable.) If all has been determined to work then it's probably the video card.
If you can do this at all I would suggest trying a new video cable they are cheap. Usually 10 bucks at the most or borrow on from someone else. If this is a DVI cable they are a little more expensive. VGA cables look like this btw http://www.networktechinc.com/cable-pc.html
Dec 08, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Emachine recovery
You should be able to just insert the restore the dvd and restart the computer and it should start automatically.
Sep 29, 2007 | Computers & Internet
FIC AM 35 Motherboard Logo
267 people viewed this question
Top FIC Computers & Internet Experts
David
David
Marvin
Marvin
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
