When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has a small indentation which seems to line up with th paper stop at the back of the feed tray
The problem is that the metal paper stop is not fully recessing into the guide at the rear of the printer and the photo paper is catching on the lip on top of the stop. Take the back cover off the printer and check that the guide has not moved out of position. Also try to twist the photo paper tray to the left or right so the stop lines up better with the guide recess. This worked for my printer tempoarily, but then things went out of allignment again, so I took a slightly more drastic step. With only a single sheet of photo paper in the tray, print another photo. When the photo tray slides back to deliver the paper to the rollers, unplug the power cord from the rear of the printer to stop the tray from moving forward again. With a pair of needlenose pliers, bend the lip on top of the metal paper stop upward. This fixed my problem permanently.
Photo smart D7560 printer. Message says photo tray problem. re insert or lower photo tray. I think I...
(More)
Photo smart D7560 printer. Message says photo tray problem. re insert or lower photo tray. I think I have done this several times. Isn't the photo tray what holds paper? what do I need to do?
my hp c7200 won't print AGAIN. I'm starting to think this printer is not worth the $$ I paid for it....
(More)
my hp c7200 won't print AGAIN. I'm starting to think this printer is not worth the $$ I paid for it. The computer used to recognize it now it doesn't.
photo tray problem !! lift output tray up , verify the photo tray is pushed un untill it stops lower...
(More)
photo tray problem !! lift output tray up , verify the photo tray is pushed un untill it stops lower output tray this is what they are telling me !!! what should i do !!
I have a mac computer now, it worked before on my windows computer.
The photo tray will not work...
(More)
The photo tray will not work from this computer
I am using a PC and cannot get my C7200 to print from the photo tray. I cannot find anywhere in the...
(More)
I am using a PC and cannot get my C7200 to print from the photo tray. I cannot find anywhere in the printer menus that allows me to specify the photo tray... also has a glitch that sends through a blank sheet before printing the object sent...I am connected to a wireless home network
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
