Home | Frigidaire | 24 in. FDB1050REC Stainless Steel Bui... | The knob broke off. How...
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Problem for Frigidaire 24 in. FDB1050REC Stainless Steel Built-in...
The knob broke off. How do I fix it?
By jagconstruct on Oct 19, 2009
Solution #1
posted on Oct 26, 2009
Not Rated)
tcochuck
Rank: Guru
Rating: 93%, 29 votes
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Was this helpful?
Yes
No
Popular Solutions for Frigidaire 24 in. FDB1050REC
Questions and Unsolved Problems for Frigidaire 24 in. FDB1050REC
Do you recommend Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher?
Answer
Answer
My Frigidaire dishwasher is making a loud pulsating noise when the water is being pumped into the... (More)
Answer
it does drain water seems to be leaking out of the float area
Answer
Hi my dishwasher comes on but does not begin the cycle. Also, there is standing water on the bottom.
Answer
- my 2year old dishwasher Fr.daire 4000 shows "PF" error message and doesnt go ahead into... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire 24 in. FDB1050REC...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
