Dell Latitude CPX PC Notebook
Problem for Dell Latitude CPX PC Notebook
I can't make any changes in bios of my dell
By swacbct on Oct 19, 2009
I can't make any changes in bios of my dell latitude cpx h500gt and i'm getting the message bootmgr is missing press alt control del
Solution #1
posted on Oct 19, 2009
Somewhat Helpful)
herminio_hal
Rank: Wiz
Rating: 82%, 47 votes
Hi, Turn on the PC while pressing F2 the bios screen will display press alt-p to go to next page boot order. CD/DVD/CR-RW Drive next is diskette drive and Internal HDD. Press space bar to change the value or the or boot order. Hope this info. will help you solve the booting problem.
HH
Was this helpful?
Yes
No
Solution #2
Not Rated)
rcxrbt
Rank: Guru
Rating: 86%, 27 votes
Make sure that you have a working and recognized hard disk.
If yes, the disk can be damaged or loss data.
Was this helpful?
Yes
No
Solution #3
Not Rated)
parrotheadpc
Rank: Guru  Dell Computer Hardware  Expert
Rating: 89%, 594 votes
Sounds like a windows issue....try this
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Was this helpful?
Yes
No
Solution #4
Not Rated)
drifterK
Rating: 86%, 364 votes
try to remove the bios battery ...this will reset to default settings ...but keep in mind that it might have a factory password....some notebooks have such thing ...
also try to press del on boot ..instead of F2 ..this should also take you to bios settings ...
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude CPX PC Notebook
Questions and Unsolved Problems for Dell Latitude CPX PC Notebook
Do you recommend Dell Latitude CPX PC Notebook?
Answer
Answer
My laptop freezes after start up. I start the computer and it runs normal until right after log in.... (More)
Answer
missing the base
Answer
I have a dell Latitude cpx. The battery is charged and it will not turn on. The power light comes on... (More)
Answer
My Dell latitude cpx. when I first received laptop it let me load my WI FI disk and card,after that... (More)
Answer
i want purchase mucic system PANSONIC OR SONY company amount should be Rs25000/- and Laptop any... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
