Sony KP-57WS500 57 in. Rear Projection Television
Problem for Sony KP-57WS500 57 in. Rear Projection Television
Turns on for a few seconds, turns green then shuts off.
By bxf704 on Oct 19, 2009
You turn Sony KP57WS500 on and it turn green right away then shuts off after a few seconds. If you turn it on again it repeats itself.
Best Solution
posted on Oct 19, 2009
Very Helpful)
Russmann
Rank: Guru
Rating: 89%, 76 votes
Sounds like you have a problem with the green crt. That is the one I've most commonly seen fail first. Your tv has three picture tubes in it that can be accessed from the front of the set. The picture tubes(crts) have a filament inside the neck like a light bulb has a filament. Over a period of time tiny particles burn off and the debris can cause a short circuit from one piece of the filament to the other. The tubes are no longer avail. as a new replacement part but the tubes in your set can possibly be saved. One trick is to lightly tap on the neck of the tube with an insulated post or screwdriver handle. Right when you turn the set on and it goes green sometimes you can lightly tap on it, (the middle tube) and knock the debris free removing the short. If that doesn't work the tubes can be rejuvinated/cleaned using a machine found in most repair shops known as a picture tube rejuvinator. My experience is that this procedure should cost 100.-200. plus service call. Most service people will tell you that this is not a guaranteed fix, but 90% of the time it works and you can get years of more use from the tv. Good luck, Russmann.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony KP-57WS500 57 in. Rear
Questions and Unsolved Problems for Sony KP-57WS500 57 in. Rear
Do you recommend Sony KP-57WS500 57 in. Rear Projection Television?
Answer
Answer
My KP-46WT510 Sony wide screen projection tv has swirly color separation mostly on the left side... (More)
Answer
the picture curves in and is blurry on my sony kp-57ws500 tv
Answer
What do i do when my sony kp-57ws5000 screen goes red completely red?
Answer
TV stays on for 20 seconds, then a blue screen appears and it shuts off. A red blinking light blinks... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
