Keyboard problem with
Im having problem with my NEC LAVIE LL500/6 laptop, the letter "h" continuosly pressed even it is not physically pressed. I dont think the problem is with my OS because it seems to be pressed even in the start-up screen before windows is loaded. Could anyone give me advice what to do? do I need to replace the keyboard?
  • Anonymous Jun 13, 2008
    I have the same problem but with the 'q' key. It also runs before the OS can load. The problems seems to come & go but has become more annoying most recently.
    I often open notepad & allow it to run which seems to possibly be to infinity. I usualy press some other key to make it (temporarily) stop.
    Have previously tried using compressed air to clean the qkeyboard (lol - thereq's the 'q' !) but this is usually a short term treatment.
  • 883 Answers
I must agree that you have a keyboard problem only.
No KB replacement should be necessary. One solution is to disassemble the KB and clean the circuit board with warm soap and water and then with alcohol. Then clean the mating contact pad (the part that is just under the key)...these pads are conductive material that lose conductivity when dusty. This is assuming your KB is the printed switch type. However, if you have the more durable type with individual switch mechanisms for each key, use the same approach but just clean the "h" key...that h switch assembly may need to be disassembled. I have cleaned these by carefully looking for the plastic latching mechanism and then inserting jeweler's screwdrivers just at these points to carefully stretch the plastic just enough to allow disassembly. Then look for the metal contacts and clean them with a good ink pen eraser.
Overall, This can be a very tedious task, so expect to put about 4 hours into it. With practice, I have cleaned complete KB's in about 1/2 hour including removal from laptop and reassembly..
Posted on Dec 29, 2007
Help me to download driver nec lavie bl350/c im here in japan i dont know nihon tnx
You can download the device drivers from the NEC WEB site.Please click on this link and select your model computer/notebook and theWindows drivers you require
Mar 15, 2012 | NEC Computers & Internet
NEC lavie LL560/M how do i turn off numlock key? whe i open my laptop its olwys in numlock
It may be set up in bios to enable that at boot but that really shouldn't be set to that by default. So I'd assume someone played in setup ?
To turn it off so you get a normal keyboard press and hold down the FN key then press (it should be) F11 You should maybe notice a light go out indicating it is turned off and you will then have a normal keyboard. That should be all it takes. If not then just reply here and we would have to check the setup etc which can be a bit more involved but nothing major to worry about.
Nov 03, 2011 | NEC LaVie S LS900/8E Notebook
I have a nec lavie lap top the has no hard drive i would like to buy one but dont know how to find the model number
This is one example,
A Harddrive's physical size is rated from it's Width. How wide across is it.
A Notebook PC harddrive is 2.5 inches across in width. (2 and a half inches)
A Desktop PC harddrive is 3.5 inches across in width.
1) You need a 2.5 harddrive.
There are two types of Harddrive technology used;
The older IDE (PATA), and the newer SATA.
The NEC LaVie S Notebook PC uses a Harddrive with the IDE (PATA) technology.
2) You need a 2.5 IDE (PATA) harddrive.
The original harddrive amount size in GigaByte's was 20GB.
{Giga = Approximately 1 Billion
A Byte is considered to be 8 characters. Whether the characters are Numbers, Letters, or Symbols}
Do I know what the largest harddrive in GB's is that can be installed?
I need the Exact model number from the bottom of the laptop.
NEC = Manufacturer
LaVie = Model Line
S = Model Series
The exact specific model number is on the bottom of the laptop. Usually in a white sticker.
This page denotes a few model numbers, I'll use them as examples,
Scroll down to the bold NEC Lavie S heading, and look at the model number examples.
With this information I can look to see what hardware is used, and possibly harddrive size limit.
Post back in a Comment.
Sep 30, 2011 | NEC LaVie S LS900/8E Notebook
Every time i turn on my laptop theres a sound, continues beeping sound,even the window display comes out.and some the letter x always comes out even thou im not typing or presing the letter x pad,the unit...
Dear Sir,
In your laptop keyboard,X key is remain pressed due to dust or by certain obstacle.So remove your laptop X key clean it brush,search for any paper pieces,staple pins,or any other obstacle by which your key remain pressed.
I think it solves your problem. if you have any problem regarding this issue leave a feedback we were happy to assist you
Have a Nice Day!
Nov 20, 2009 | Computers & Internet
Nec lavie ll350/c drivers
You can download drivers from the NEC WEB site, their support/download page. Make sure you select your model laptop and the correct Windows version of the driver you require.
Use this link :-
Mar 25, 2009 | Computers & Internet
Need driver for NEC LaVie C LC500/3 laptop
Hello friends,
I Have a Nec Lavie C LC500/1 Laptop it in audio sound not playing. but it is driver already it have. I put Head set also it:s
not working please help me
Jul 03, 2008 | NEC LaVie S LS900/8E Notebook
LaVie PC-LL350BD
Your solution is a easy one. Goto your favorite search engine. Type in NEC lavie ll350/b support. Find the web site that has your manufacture. When you are in the web site find the word support and then find your particular model. Once you click on it you will get a download page with drivers and manuals. Click on the drivers you need. Download them then run them on your computer.. this should fix your problem.
Sep 22, 2007 | NEC LaVie S LS900/8E Notebook
Computers & Internet Logo
417 people viewed this question
David Payne
David Payne
