Question about Kenmore 15129 Built-in Dishwasher
Westinghouse freestyle 920
We have a problem with water leaking from what we think is the front two sides. we have replaced the pressure switch and the rubber seals on both sides. We have hardly used the dishwasher it is about 5 years old.
Can anyone please offer a solution.
Thanks
MRG
  • 33 Answers
Was there damage to the door,when the door closes is it closing freely or is it hitting the cabinet on both sides it may need to be pulled out about 1/2 "
Posted on Dec 31, 2007
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Apr 19, 2017 | Westinghouse Refrigerators
Westinghouse 920
This most likely the fill valve that is leaking. See if there is a valve that is connected to it under the sink, turn it off and see if it still has the problem. If the problem goes away you need to remove the unit from where it is installed and replace the fill valve.
Feb 09, 2014 | Westinghouse Dishwashers
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
Coolant Leak intermittently
use a pressure tester on the cooling system, that should show you were its coming from with out getting thr engine to hot for you to work on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_4c166ba81493f541
Jan 24, 2018 | 2005 Ford Freestyle
My 2005 ford freestyle gets wet on the passenger side when it rains
it is where a hose comes throguh the firewall, There is a TSB on this.
adobe.gif Printable View (70 KB) TSB
06-2-6
  • WATER LEAK IN RIGHT FRONT OF PASSENGER COMPARTMENT
Publication Date: January 17, 2006
FORD: 2005/06 Freestyle
ISSUE: Some 2005 Freestyle vehicles may exhibit a water leak at the right front passenger compartment. This may be due to grommet for rear washer fluid line at dash not being fully seated.
ACTION: Inspect windshield washer grommet from inside vehicle under dash and properly seat if out of position. Pull carpet back and reach under bulkhead pad to install. Removal of instrument panel is not required. (Figure 1)
Dec 14, 2010 | 2005 Ford Freestyle
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
internal water drain is blocked - get very thin copper wire and unblock -
Jul 30, 2010 | Microwave Ovens
Coolant Leak at Engine Oil Pan
CHECK FOR LEAKING WATER PUMP WEEP HOLE OR GASKET.ALSO CHECK WATER PUMP HOSE FOR LEAKS.IF ALL LOOKS GOOD.YOU COULD HAVE PINHOLE LEAKS IN RADIATOR CORE LEAKING ON FRONT OF ENGINE OR INTAKE MANIFOLD GASKET LEAKING COOLANT.
Jun 08, 2010 | 2001 Jeep Grand Cherokee
Door seals rotting out on westinghouse freestyle 920 dishwasher
If the machine is kept idle for long time without use, these types of problem happens.
When not in use, apply talcum powder over the gasket. Moist the powder and apply as it will fall off . Leave the door slightly open by keeping some folded cloth or some other soft material and close the door.
Contact the service provider and protect the electronics by a water-resistant cover.
May 26, 2010 | Kenmore 15129 Built-in Dishwasher
Front of dishwasher leaking from sides.
I think it is the seals...even though they look good they can be compressed and loose the eleasticity to swell and seal....
Here is a tip that I wrote about leaking dishwashers
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Apr 22, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Main power safety tripping when i turn on dishwasher power - Help
in the long run i would go with a new one...use less power get parts longer looks better wife will be happy hi hi
Aug 17, 2009 | Dishwashers
Kenmore 15129 Built-in Dishwasher Logo
840 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
