Hitachi 55HDT79 55 in. HDTV Plasma Television
Problem for Hitachi 55HDT79 55 in. HDTV Plasma Television
Have a line running thru my screen. hitachi
By carljenn on Oct 19, 2009
have a line running thru my screen. hitachi ultravision 55hdt79
Solution #1
posted on Oct 19, 2009
Somewhat Helpful)
techbuster
Rank: Guru
Rating: 89%, 515 votes
he Control PWB only causes this defect when the Backlight Control Signals are Output from the Control PWB No LVDS(Low Voltage Differential Signaling) signal may also result in this symptom
LVDS is a differential signaling system, which means that it transmits two different voltages which are compared at the receiver. LVDS uses this difference in voltage between the two wires to encode the information. The transmitter injects a small current, typically 3.5 mA, into one wire or the other, depending on the logic level to be sent. The current passes through a resistor of about 100 to 120 ω (matched to the characteristic impedance of the cable) at the receiving end, then returns in the opposite direction along the other wire. From Ohm's law, the voltage difference across the resistor is therefore about 350 mV. The receiver senses the polarity of this voltage to determine the logic level. This type of signalling is called a current loop.
Its completely signal faults in your circuit board. So only its difficult to understand without yechnical knowledge.
You need to check the PWB or LVDS system.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 55HDT79 55 in. HDTV
Questions and Unsolved Problems for Hitachi 55HDT79 55 in. HDTV
Do you recommend Hitachi 55HDT79 55 in. HDTV Plasma Television?
Answer
Answer
the first problem was that a picture froze on the screen and never left , it was still frozen there... (More)
Answer
Hitachi 55HDT79 Plasma - Will not turn on. No Red or Blue light showing on front. Unplugged and... (More)
Answer
I have yellow,red, green, orange lines across the top 3 inches of the screen, shows up bright when... (More)
Answer
Purchased the TV on the spot on NOVEMBER 23, 2007. NOV 24/07 Follow-up call I made to Fast Forward... (More)
Answer
TV goes in and out. Blue light blinks between picture grabs. Other internet postings say. Main... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 55HDT79 55 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
