Question about Nikon 105mm f/2.5 Nikkor Ai-S Lens
Aperture cannot open fully
Just bought my 105mm/2.5 ais recently. The diaphragm worked normally when i turn the aperture ring. However when i mounted it to my FM2. i was not able to open the aperture fully when i was at full close focus(lens fully extended). this happens when i put the aperture at f22. It open fully at larger aperture. When i released the shutter, the aperture closed to its minimum and refused to open (sometimes it open v slowly) This problem does not happen when I am at far focus(lens fully retracted). I've sent the lens back for lubrication but it came back with the same problem. Any idea wat's wrong and how to rectify it? Thanks
  • Anonymous Mar 15, 2014
    Often the lens automatically close.
  • 667 Answers
As you have found out, it is not a lubrication issue. It would seem that your lens has a problem with the linkage arm inside the mount. The arm that extends out of the mount could be bent or misaligned. It would be fixable, but the parts are somewhat delicate. Best to let a good repair person have a look.
Posted on Dec 29, 2007
My Nikon D5000 isn't recognizing my Sigma 35-105 lens. Why?
Is this an older manual focus lens? If so, it lacks the electronics to communicate with the camera. You have to set the camera to Manual exposure mode (turn the mode dial to "M"). Set the shutter speed on the camera body as usual and set the aperture by turning the aperture ring on the lens. You'll have to set the exposure without any help from the camera's light meter.
Feb 13, 2013 | Sigma Nikon 35-105mm F3.5-4.5 Ai-s Ais...
Sometimes pictures are dark even in auto mode, err message is always coming, dark image in the view finder.
Hi dear pmorala
1) check
the lens if to drive the diaphragm actuating lever that opens.
2) also check the aperture lever on the camera body may be broken or bent.
3) look at the Shutter release the mirror and shoot the camera in a low speed (M mode) note if this works correctly or some of the leaves that make up the curtain is loose or out of place.
Everything seems fine ... OK command dial to select the full aperture, shoots the camera at you and see the diaphragm (set M mode and speed sh bellow 1 / 8). Full closed? = Aperture Mechanism defective.
Regards
Mar 16, 2011 | Nikon D90 Digital Camera with 18-105mm...
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change...
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
Mar 06, 2011 | Sigma Telephoto 105mm f/2.8 EX Macro...
The lens is used on a D200 and the camera shows it's a non-AI lens. The aperture will not work in auto.
Turn the aperture ring to its smallest setting (largest f/number). Control the aperture from the camera, the same way you do so on a lens without an aperture ring.
Aug 27, 2010 | Nikon 80-200mm f/2.8D AFED Lens
According to the manual for my Sigma 105mm f2.8 EX DG Macro lens with my Nikon D90, when using P or Sutter priority auto mode the diaphragm control ring needs to be set to the smallest aperture(f32) and...
In all modes the aperture ring on the lens should be locked at the smallest aperture. In the M and A modes you control the aperture by turning the command dial on the front of the camera. In P and S modes you control the aperture indirectly by turning the command dial on the back of the camera.
Aug 04, 2010 | Sigma Telephoto 105mm f/2.8 EX Macro...
The lens only meters at F22 at other aperture setting it displays
That's the way it's supposed to be with all modern Nikon bodies. Keep the aperture ring at f/22. Adjust the aperture by turning one of the command dials on the body.
If that doesn't work it, please append a comment to this post specifying the body or bodies you're using with this lens.
Jul 31, 2010 | Nikon Telephoto 500mm f/4.0 P ED IF AIS...
Manual lense not working on f5 as aperture ring is sticking
little spring inside body behind mount has come of; open and repair; not difficult
Jul 16, 2009 | Photography
Nikkor 105mm Ai-S micro lens aperture seems stuck
It does sound like your lens diaphragm/aperture ring coupling mechanism is in need of repair.
May 03, 2008 | Cameras
Camera (D200) no longer sees that the diaphragm lock is on. If I jiggle the diaphragm ring it works for amoment. How do I fix this?Thanks
With the lens off, look at the camera mount area. If you are looking straight at the mount, there is a small tab sticking out at about 7oclock on the outside edge of the mount ring. The tab is spring loaded and may be damaged. You should be able to push the tab toward the base of the camera and it will snap back if functioning properly. If it feels loose or doesn't spring back, then switch that ab controls is not being activated.
Oct 24, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Repairing 20mm af nikon lens diaphragm lock
I'll offer the same answer I just gave on a D200 question: With the lens off, look at the camera mount area. If you are looking straight at the mount, there is a small tab sticking out at about 7oclock on the outside edge of the mount ring. The tab is spring loaded and may be damaged. You should be able to push the tab toward the base of the camera and it will snap back if functioning properly. If it feels loose or doesn't spring back, then switch that ab controls is not being activated.
Nikon 105mm f/2.5 Nikkor Ai-S Lens Logo
264 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
