Question about Nikon F65 35mm SLR Camera
Shuttle speed is slow, Do I have a setting off
  • 45 Answers
Is your camera has option to change to shutter speed?
Posted on Dec 29, 2007
Slows Down and Then Speeds Up
It probably has to do with the belt overheating the motor and irritating your controller. Try replacing the walking belt.
Oct 23, 2017 | Nordic Track NordicTrack Treadmill, A2550
Slow sound on window xp
Change playback speed in Windows Media Player
Begin playing a file.
Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
To hide the settings, click the Close button in the Enhancements pane.
hope this helps
Jul 30, 2012 | C-Media Electronics Computers & Internet
My shutter speed is very slow and when I take pictures I think when it's dark is when I notice the problem but the picture will not take. Also if someone moves their face is blurry.
What mode are you shooting in? It seems you may either have your shutter speed set manually to a slow speed or, alternatively you have set your apperture set to a high number e.g f/20 or there abouts. Because this is a very narrow apperture the camera will compensate by using a slow shutter speed.
Try some shots in fully automatic mode and see what happens. With a slow shutter speed you can expect any movement to produce blurred images.
Oct 21, 2011 | Nikon D90 Digital Camera with 18-105mm...
I need to know the capacity for MEMORY AND THE TYPE SPECIFIED
According to the manufacturers specs these are the memory specifications you need, and the maximum the motherboard will accept...
3 x 168-Pin DIMM-socket
for up to 768 MB memory SDRAM
with 8, 16, 32, 64, 128 and 256 MB size
Dec 28, 2010 | Shuttle Slot A AI61 (MBAI61) Motherboard
Begins to engage at first at a slow speed then stops engaging. the motor sounds like it is running, but the needle is not moving.
What seems like motor running isn't so. The motor is actually stopping and the sound u get is from the winding. You should immediately raise yr foot from the foot pedal and stop supply to motor. Other wise you run the risk of loosing yr motor.
Your problem is due to something getting jammed in yr bobbin compartment.
Clean shuttle race and shuttle race free of lint regularly to avoid this.
Oct 16, 2009 | Sewing Machines
Have athlong xp 2500, shuttle an35n ultra mother
I think that you might be asking about latency timings... Try downloading NVIDIA's Performance software. If you search google with those two words you will likely find it. When you install it, look for system settings and whatever you can change there, will be all that your MoBo allows you to change.
Oct 02, 2009 | Shuttle AN35N Motherboard
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Mar 16, 2009 | Baby Lock BL1556
Warning lights staying on after engine started
probably the shuttle valve in the ABS unit is defective, solution renew shuttle valve, dont let dealership sell you a new ABS unit very expensive
Mar 08, 2009 | 2000 Land Rover Discovery
I did go to Shuttle to look for a bios upgrade & Shuttle does not list any bios files. I found one bios file at Softpedia & downloaded it to see the date. The .rom file is dated 11/28/2003. I gather your 2003 is close.
The current bios does not allow you to clock the CPU to its correct frequency.
AMD XP 2400+ frequency
Bus speed (MHz) = 266
Clock multiplier = 15
You can try turning on the over clocking, see the manual page 57. These setting would be normal for the AMD XP 2400+ CPU.
I'm looking at the max frequency for the Shuttle is topped out at
198MHz. As far as the IDE hard drive I'd like you to download the manufactures bootable floppy software & check the drive with this floppy disk. (Works in a dos like mode). No windows involved. The Mfg's software will test & repair the drive if needed & will also set the drive up, set cluster size, choose NTFS FAT or any other FAT you wish for windows XP. It's better than windows format. You'll fine there are other options you can turn on & off if you wish. (If you run the Mfg's software, disconnect any other hard disk drive by removing the data cable).
On a personal note, I always use the Mfg's bootable software to set up any drive be it IDE or SATA I, SATA II.
Shuttle site's.
Live chat:
Good luck cfuller77!
If you find you need more help, just ask...
Jul 13, 2008 | Shuttle MK40VN Motherboard
My shuttle wont boot
If it's a new build, can you give details on processor etc. But if there is no bios, it's normally a memory incompatability problem, or the processor isn't active.
Jan 08, 2007 | Shuttle SN41G2V2 Barebone
Nikon F65 35mm SLR Camera Logo
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
