Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Bar on my Dyson wont turn
The Bar Wont Turn and I cant figure out how to check the belt
  • 328 Answers
If its a standard DC07 you can check the belt by loosening the pegs on the sole plate with a coin. Once this is taken off you can inspect the belt.
If you have an All Floors model/Green DC07 then the drive belt is a sealed unit which cannot be replaced and must be fixed by an engineer.
Posted on Dec 29, 2007
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
How to get at beater bar belt on dyson dc 28?
Hi there, it's Jack at Dyson.
DC28 includes a durable belt engineered to last the lifetime of the vacuum in normal use. It's part of the high-torque clutch mechanism, and we wouldn't recommend attempting to access or remove it as this could damage the machine. The belt is protected by a sensor which will shut off the brush bar for protection if something jams it, so it's very unlikely the belt itself would be at fault.
If the brush bar isn't rotating, the machine may need a simple reset. After checking the cleaner head for any obstructions, you should be able to reset the vacuum following the steps shown in our video guide:
If you continue to have difficulty after trying this, please contact our experts directly for further assistance. If a repair is needed, we can also confirm if this is covered under the 5-year Dyson warranty. You can reach us by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jul 20, 2014 | Dyson DC28 Animal Upright Vacuum New DC 28...
Beater bar wont spin
hello rud.... this is due to either a broken belt or lots of carpet fibers or pet fur in the beater bar mechanism. turn it off, unplug it and then turn it on it's side and check to see if the bar turns freely by hand. if it does, you will have to replace the belt assembly.... most dyson's have the belt built in to a plastic housing forcing you to buy a pricey part. Joe
May 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
The beater bar is not turning and the belt is still on it and not broke. it turns easy when i do it but will not work when i turn it on
The problem is that the belt is stretched. The belt may not be broken but if it is stretched or worn then it wont be able to turn the brush against the resistance of the carpet. Here is a link to the belt you need and to a manual you can view:
Dyson DC07 Belts and Manual
Nov 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
It wont vaccum
If the brush isn't turning you need to replace the belts. You can get replacement belts here:
Dyson DC14 Belts
Nov 21, 2009 | Dyson DC14 All floors Bagless Upright...
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
BAR NOT TURNING
The bar is not atached to the drive belt or the belt is broken
Jun 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
Feb 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
54 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
