Question about Samsung SPH-m520 Cell Phone
I tried using a Q7 bluetooth but can't hear
I tried using a Q7 bluetooth with my samsung m520 phone. It is paired and I can control my phone using the headset but I can't hear out of it. The volume is up and other phones worked fine with it. Is my phone not compatable with this particular bluetooth? I've used other blutooths before and they worked fine.
SOURCE:
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
  • 117 Answers
SOURCE: CAN'T GET MY MUSIC PLAYER TO PLAY VIA MY SBH-170 BLUETOOTH HEADSET
I think the samsung T629 does not have stereo bluetooth. It would have to have a 2.0 class bluetooth profile to play music through the headset
Posted on Jan 20, 2008
SOURCE: bluetooth headset
THank you thank you.. you helped me solved my problem 0000 password
Posted on May 29, 2008
Bajanguru
  • 7752 Answers
SOURCE: Bluetooth not working anymore
CYBERSOUL - take the phone to a mobile center and ahve them correct it for you.
Posted on Jun 29, 2008
SOURCE: Can not pair cell phone with Bluetooth.
I neglegted to put the Bluetooth in pairing mode.
Posted on Dec 01, 2008
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play,...
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
Feb 08, 2015 | Samsung Radio Communications
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
Q7 bluetooth manual
Pairing code is 0000 (4 zeros).
Download manual from here.
Nov 04, 2013 | Cell Phones
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
No audio
not sure about the bluetooth settings on an Iphone sounds like the speaker may be broken. have you tried pairing it with another phone if it works on another phone its probly just settings
Dec 02, 2011 | Samsung Wep470 Bluetooth Headset
How do you pair the Q7 bluetooth with a bluetooth enabled phone? I know the code, but don't know what mode the headset should be in.
Please, take a look at this generic and simple guide, about pairing bluetooth headsets, I posted some time ago.
Hope it can be useful to you, somehow. Otherwise, please let me know, I'll try my best to fetch specific informations for your case.
Regards, Carlos
Jan 16, 2011 | Cell Phones
Can't connect a motorola hs850 with a samsung m520.
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Jun 23, 2009 | HTC G1 Smartphone
How to make the cell phone communicate with computer using Bluetooth technology
hie dear,
for connecting ur cell to ur pc's bluetooth, u should have either inbuilt bluetooth or external proper installed bluetooth in ur pc.
do u have?
if so, then activate the bluetooth of ur cell as well as of ur pc and search through pc's bluetooth applicaton. its really very easy, u hv to follow the instructions only.
bunty
May 06, 2009 | Samsung SPH-m520 Cell Phone
Jawbone bluetooth won't pair with phone.
sometimes the phone will not pick up on certain bluetooth headsets so i recommend a Motorola.
Apr 28, 2009 | Samsung SPH-m520 Cell Phone
Help????
they can connect only iff both have bluetooth facility.just turn on boths bluetooth from conectivity options.search for other device from any one of them.after few seconds first device will find other in between its bluetooh network.then request from one to other for conect.other phone will get firsts request.accept it by clicking on acept or yes option whichever appears on the phones screen.than both phones will be connected.just simply use them.
Jun 28, 2008 | Cell Phones
Samsung SPH-m520 Cell Phone Logo
467 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
