Question about Motorola Mobility RAZR V3
Master reset The recommended solution for trying to get the setupHome done was a master reset. How do you do that?
Go to settings, hit 5 (initial setup), find master reset on there...second-to-bottom....click on it, your security code should be 000000 ( ZEROx6 ) and then....yay?
Posted on Dec 29, 2007
Nokia 1110 SECURITY CODE
You can try the default security code 0000 or 12345 .If its not work master reset your mobile.This can be done through codes.If you need a master reset code for your mobile at http://www.unlock-free.com/ . you can use this and reset your mobile easily.
Apr 06, 2012 | Cell Phones
I forget my posward plz give the security code
If you forgot the security password, then you need to master reset the phone. I recommend you to contact your service provider to get the master reset code.
Aug 31, 2011 | Cell Phones
I forget my security passwod.now my phone is locked.i want to beak my security code
If you forgot the security password, then you need to master reset the phone.I recommend you to contact your service provider to get the master reset code.
Jul 30, 2011 | Nokia 7210
I forgot my phone lock in 3660 how can i retrieve it ?
Try deafault codes 12345 , if not the only way out of this is , you have reset your phone, try getting reset codes from http://www.simpleunlocking.com/nokia-dct-master-code-service/rs16wp10/ to master reset your phone back to normal
Jul 30, 2011 | Nokia 3660
The master Code 12345 is not working on my mobile, i want to reset all my settings.
try this solution. it was copied from another forum
Hard ResetIt may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
  • Enter the code: *#7370# and press Yes to confirm initialization.
    • Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
  • To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
  • on/off + * + 3
    • Before making a Hard reset better backup all your important information: contacts, memo...etc
Jun 14, 2011 | Nokia 7210
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Forgot security Code Of nokia 5130
You have to master reset your mobile..This can be done by codes..If you need a master reset code, get it from Unlocking4free.com .Here you can get the free master reset code...
May 31, 2010 | Nokia 5130 Cellular Phone
Samsung z500: when on a call, the call goes ok, until it becomes time to hang up, then it freezes and wont let you hand up or do anything, i end up having to remove the battery and re-insert it doing a...
In my opinion, I would recommend doing a master clear and master reset. Completely clear out the phone memory.
Sometimes a MMS can contain a virus, or if the phone memory gets too full, it can cause glitches and hang ups.
Jul 30, 2008 | Samsung Cell Phones
Satalite Signal?
Have you tried resetting the unit? Have you done a master reset? If not, try these. Just be aware, a Master Reset will ERASE ALL YOUR FAVORITES.
Feb 15, 2008 | Garmin StreetPilot C330 GPS Receiver
SetupHome
try and do a master reset and master clear.........if that does not help...you will have the reflash the firmware on your phone , so take it to a mobile tech and have them reflash it for you.
Dec 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
