Question about Sony Playstation 3 (PS3) Console
Ps3 Won'T play ps2 games.
I have herd about a downloadable fix but can't find it. HELP!!!
  • 36 Answers
The newer lower priced PS3's dont have ps2 backward compatibility. They don't have the built in hardware to do it hence the cheaper price. Maybe sony will release a software emulator for these units if enough people complain.....but one can only wait and see. The 80 GB higher priced one does however have the backward compatibility.
Posted on Dec 29, 2007
I live in South Africa and bought a PS3 Baseball game. It works in my PS2 but not in the PS3, because of the zone code. What is the correct zone code
I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region
00: NTSC J
01: NTSC U/C
02: PAL
03: PAL
04: PAL
05: NTSC J
06: NTSC J
07: NTSC J
08: PAL
09: NTSC C
11: NTSC U/C
12: NTSC J
Apr 29, 2012 | Sony Playstation 3 (PS3) Console
How do you set up playstation 3 to play playstation 2 games
One Surefire WayThe only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can’t, and there’s not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won’t help you out much here.
However, if you do have the correct console model, then there isn’t much to know for learning how to play PS2 games on PS3. Simply insert the game CD or DVD (many original Playstation games are also supported thankfully), and the game will start up. Sometimes, it will tell you that you can’t play the game, but simply hook your PS3 up via wireless or ethernet connection and update the firmware (which also provides improved compatibility with newer versions of Blu-ray discs). Often, this will fix the problems, but not all PS and PS2 games are supported (although most are).
There you have it. Learning how to play PS2 games on PS3 is easy, but if you just randomly picked a Playstation 3 model out at your local retailer, you might have a model lacking in backwards compatibility. One reason they didn’t include such compatibility with all models is an issue of cost, as it saved Sony some money to not include such a feature on all of the models. When they first started selling PS3s for $400, they were losing several hundred dollars (although they are at least breaking even now). Unfortunately, both the new 80 Gb and 160 Gb PS3 models are lacking in such compatibility, so you’ll need to find older models to support your older games.
Please rate my solutions! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
PS3 is backwards compatible with PS2 games, and USED to play them
In Playstation Store, you should download (for free) the PS2 SYSTEM DATA (something like this).
if you have formated your system, the files were erased, and the games won't play until you download the backwards comparibility files again.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
Running ps2 games on my ps3
Be sure that your Playstation 3 is up to date
Or go to the Playstation Store and download Playstation 2 Download this will help fix the problem
Or Make sure the game isn't scratched or damaged
May 04, 2009 | Sony PlayStation® 3 (60 GB) Console
How to play ps2 game on the ps3
Playing a PS2 game on a PS3 depends on what model your PS3 is. The 40 GB does not play PS2 games, the 60 GB definatly does ,and i dont think the 80GB does
Mar 28, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
Cant play ps2 games on ps3
you cant play ps2 games on a 40 gig PS3. only of 60 and 80.
plz rate awnser.
Jul 22, 2008 | Sony PlayStation® 3 (60 GB) Console
PS3
Ps3 supports over 1000 ps1 and ps2 titles. Make sure you hook your ps3 up to the internet and download the latest firmware updates. Odds are your system will be able to play all or most of your ps2 games once you update the ps3 online.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
