Question about HP ScanJet 4670 Flatbed Scanner
HP Scanjet 4670 carriage problems
My brother in law has given me an HP ScanJet 4670 that he says is not working. I connected it up and confirmed the fact that it does not scan. What happens is that when the scan hits the right end the carriage stops. There is a stepper motor that moves the carriage. The opto switch is not engaged properly and the mechanism continues to move. I have tried to manually block the sensor but it continues to try to scan. Moreover, the scanner seems to scan in a fashion that I get a page full of black and white stripes even when scanning a document. I checked the flex cable that connects to the PCB board (PN 105-0738-0) and it seems to be okay.
What could be causing these problems?
  • 2 more comments
  • bille Jan 09, 2008
    Carriage problems... how about the thing never works, no matter what driver or software is loaded. I have owned this scanner for 2 years (???) and it has only worked once. Anyone find a way to make this scanner work?
    Rhonda
    mylifeisgood48@yahoo.com
  • Richard Yngente
    Richard Yngente May 16, 2008
    im also have a problem about this product since we buy never works but to bring again to the hp services is to much far and the warranty is only to the limited area. when u connect the scanner to pc they dont have power.but i test the power connector is okey.
  • berserk888 Dec 16, 2008
    I have exactly the same problem, I dont' know what to do.
  • Anonymous Dec 26, 2008
    Amazing. 26/12/2008 and same problem without solution.
jackboy
  • 2985 Answers
SOURCE: No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Posted on Jun 14, 2007
bandana_gyrl
  • 181 Answers
SOURCE: HP Scan Jet 3200C scanning problem
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
Posted on Feb 28, 2008
mohanchennai
  • 490 Answers
SOURCE: Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Posted on Apr 06, 2008
  • 237 Answers
SOURCE: HP 4670 Scan to email: how to open Windows Live mail, not OE
Click the Show Menu button, and choose Options; if you see the traditional menus, go to Tools > Options. Both open the Options dialog: under the General tab, which should be selected by default, locate the bottom section, labeled "Default Messaging Program":
img1a2.jpgIf Windows Live Mail is not currently the default email program on Windows, the text next to the first button will read "This application is NOT the default Mail handler". Click the Make Default button, and it will be disabled (grayed out).
img1d.gif Confirming your change of default email clientThe text has now changed to "This application is the default Mail handler".This is a bit misleading, because Windows Live Mail will not becomeyour default email application until you actually have clicked the Ok or Apply button to confirm the change in configuration.
img36wlm.jpgSoclick Ok (no need to Apply first), and Windows Live Mail's optiondialog will close, integrating your new option choices. It is that easyto make Windows Live Mail your default email program. (If Windows LiveMail was already your default email client, nothing will happen.)
Posted on Nov 19, 2008
SOURCE: HP Scanjet 5370C circuit board resistor 105 burned..what is size?
http://en.wikipedia.org/wiki/Resistor
Posted on May 13, 2009
HP ScanJet 4670 - yellow lines or streaks in scans
You have a dirty glass. Take a lint free cloth and water and wipe the glass making sure you leave no streaks behind. Sometimes you have to take a flashlight and examine the glass. Just a little spec, the laser will drag all the way down.
Aug 30, 2017 | HP ScanJet 4670 Flatbed Scanner
Where do I find 64 bits drivers for HP Scanjet 4670 Thanks in advace.
Please click on the link below and choose the windows version according to the one you have to download the 64 bit drivers you need for your scanner.
Link
Feb 20, 2011 | HP Scanjet 4670
Hp scanjet 4670´s tma does
I'm afraid there are no drivers running under Windows Vista for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD (
http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD (
http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
Dec 31, 2010 | HP ScanJet 4670 Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
No OS 10.5 driver for hp 4600 scanjet
Hi ,
Kindly Copy the below Link to an Browser for Downloading the Mac Driver.(Copy & Paste).
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=297431&prodTypeId=15179&prodSeriesId=297429&swLang=8&taskId=135&swEnvOID=219
May 23, 2009 | HP ScanJet 4670 Flatbed Scanner
HP ScanJet 2100C
I had a similar problem when I upgraded to Vista. Try running setup.exe from within the software CD ( in the english folder I think) rather than using the autorun.
Oct 30, 2007 | HP ScanJet 2100C Flatbed Scanner
HP ScanJet 4670 Flatbed Scanner Logo
468 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
