Home | Escort | Passport 8500 Radar Detector | Starts going off whe...
Escort Passport 8500 Radar Detector
Problem for Escort Passport 8500 Radar Detector
Starts going off when a higher speed is reached
By sylwia1231 on Oct 19, 2009
When pressing fast on the gas pedal the radar signal goes off and LASER appears in the window...It gets a little annouying, bacuase as i let off the gas it stops and press the gas again it starts again. Any ideas?
Solution #1
posted on Oct 29, 2009
Somewhat Helpful)
EECS
Rank: Wiz
Rating: 77%, 17 votes
THis is a weird one! The only thing that makes sense is some sort of interference that is impacting the electronics inside the detector. Sometimes ignition "noise" can cause this behavior. I have seen ignition noise so severe that a Garmin GPS would not work inside the car.
Can you test this without moving the car? If you rev the engine while the car is parked, does the detector still go off? This will allow you to determine if there is some form of intermittent operation inside the detector caused by solder joints, etc., or a problem associated with electrical noise.
BTW, what type of car do you have?
Was this helpful?
Yes
No
Popular Solutions for Escort Passport 8500 Radar
Questions and Unsolved Problems for Escort Passport 8500 Radar
Do you recommend Escort Passport 8500 Radar Detector?
Answer
Answer
My passport 8500 keeps showing this "service required" sign. how do I fix this?
Answer
I have an Escort Passport 8500 X50 which I have owned for apx 2 years. It now occasionally sends a... (More)
Answer
starts to calibrate for a while then goes to service required
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Escort Passport 8500 Radar...:
Top Radar Detector Experts
Rank: Guru Guru
Solutions: 14736
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Radar Detector Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
