Question about AEG Lavamat W1450 Front Load Washer
AEG 72640 Washing machine
I have an AEG 72640 washing machine. It seems to be stuck in half rotation. It will only turn half a revolution then the power cuts out completely, it will then try again, with teh power cutting out completely again etc. Is it the circuit board has it gone?
    President:
  • 1,294 Answers
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
My 72640 AEG washing machine continually leaks even though the filter cap is tightly in place. What could be the problem please? Kate Comins
you have a hole in the rubber boot seal and need to change it,also i've seen a buildup of detergent and hair stuck on the bottom side of the front door,when the door is closed the water was traveling down the pieces of hair and leaking through the bottom of the door,but if it's leaking under where the pump is and it's not the pump or hoses it's the boot seal.open the door and pull open the boot seal and run your fingers all around until you find the hole
Jan 23, 2011 | AEG Lavamat 72640 Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Aeg washing machine
Click on 'washing machines' (below FIXYA) on this website, & search witrh your model number. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
May 30, 2008 | AEG Lavamat 72640 Front Load Washer
2 problems here with my AEG 72640
we had a similar problem(45mins) we were about to purchase a new one when by sheer luck i noticed the on/off socket(not plug) above worktop was buzzing, pulled machine out put in different socket and has been ok since. Try it, it could help.
Jan 25, 2008 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72640
Probably the motor is broken. Or the tachometer is loose from the motor.
Dec 26, 2007 | AEG Lavamat W1450 Front Load Washer
Washing machine-dryer AEg
it could be the drum bearings going
Nov 05, 2007 | AEG Lavamat 72640 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat W1450 Front Load Washer Logo
210 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
