You have to check the ignition system . may be the ignition system of your car has a problem it could be a short circuit or corroded or dead battery problem. In the end you have to check the ignition system .The ignition system of your car .Locate the parts of the ignition system of your car.Then look check the ignition switch ,ignition coil,distributor assembly,spark plug.
Check for corroded switch,check ignition coil,check distributor assembly,
The contact point gap
the condenser
check the high tension wires and terminals.Check wires and connections.Check the spark plug gap.And always observe safety rules . All of those parts that are worn out , you have to replace them .Make sure to clean the corroded parts. If the owner cant do the job.he or she is advice to go to a car shop mechanic and let them do the job.
It was the security system. I disconnected the battery for 10 mins and reconnected. Problem solved!
Same thing just happened to me on my nitro. Neither key would start the car. The hint was that the key would not operate the door locks and the red security light was oon solid. I removed the negative battery cable for 3 minutes and put it back. wala car started no problem. Some how the security system kicked in and locked out the keys from starting the nitro even though I had power to ligts . . radio ect.
