Question about Canon PowerShot A520 Digital Camera
Powers up and then shuts off
The batteries went dead while using the video mode. It didnt zoom back in and shut off, it just quit and left the zoom sticking out. After changing the batteries it now powers up, says CANON with the blue background. Then it beeps and shuts off. What can I do?
  • Canon Master
  • 4,738 Answers
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 31, 2007
WHERE IS THE GROUND WIRE IN MY 2003 KIA SPECTRA
Check your battery and cable and ground connections. check also your alternator belt (drive belt). Have your battery checked at any autoshops.
Apr 17, 2017 | 2003 Kia Spectra
Just got my transmission replaced, now it SEEMS like my alternator is out. when i got my car back, the battery light was on and flickering. one day i went to the store, when i cane back out and started my...
HAVE YOUR ALTERNATOR TSTED AT A PARTS STORE
YOU SHOULD GET BATTERY TESTED ALSO
WHEN VOLTAGE GOES DOWN IT WILL SHUT OFF COMPUTER
CAUSING CAR ENGINE TO SHUT DOWN SOMETIME JUST SITTING THE BATTERY COULD
RECUPERATE A BIT TO LET ENGINE START AGAIN BUT ALL POINTS TO ALTERNATOR
Apr 19, 2011 | 2000 Mercury Cougar
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
Won't Power On (Yes, I've checked the battery!)
could be that the lens is not coming all the way out... turn on in playback mode to see if it stays on. does sound like repair
Feb 12, 2009 | Olympus FE-370 Digital Camera
Camera keeps shutting off when I zoom in
SYMPTOM =
Camera suddenly powers down.
POSSIBLE CAUSES =
* The function of POWER OFF in (Setup) mode has been activated.
* The battery has run out.
SOLUTIONS / CORRECTIVE ACTIONS =
*Set the option of POWER OFF to OFF.
*Turn the power back on or charge the battery.
Let me know what happens and thank you, Binary Bob
Nov 30, 2008 | Vivitar ViviCam 5386 Digital Camera
Zoom and camera shuts off
Verify you have the right kind of battery and fully charge it.
The lense issue you describe commonly happens when the device cannot access enough power to function correctly, so it retracts and powers off to avoid getting your lense stuck in the 'out' position if the battery goes dry.
Apr 27, 2008 | Kodak EasyShare One Digital Camera
Powers off only when I hit the zoom button......
The zoom mechanism is shot- Kodak will quote a repair price you wont like.
Mar 20, 2007 | Kodak EasyShare Z700 Digital Camera
Camera only half operates: preview mode OK, picture-taking mode not working
Mine shuts off when I press the shutter button. I put in new batteries and I can get the lens in then. But it shuts off when I try to take a picture. These cameras are notorious for having a zoom problem. They say the Zoom error appears and the camera dies. There is a fix of gently pulling the lens out all the way till the cover open then twisting it gently clock wise till it clicks. They say this fixes this problem but I don't think that is what is wrong with mine. Do a search on Fuji E550 zoom problem fix. It should show up.
Feb 16, 2007 | Fuji FinePix E550 Digital Camera
When turned on, lens goes out then right back in, eventually camera shuts off. view mode OK.
This might be an E18 lens error issue. Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 04, 2006 | Canon PowerShot A75 Digital Camera
Camera powers up but then shuts down
Check out this similar post - http://www.fixya.com/problems-solutions/t103765,p241282/Ricoh-Digital-Cameras.aspx In your case though, I would try to turn it on with playback mode selected on startup, to prevent the zoom from extending. This way you will know if the problem is connected to the zoom, or other mechanisms. In any case, if it's not a battery/battery door/card problem, you'll need to send it for repair, or find a shop that can handle it, and it's rarely a cheap repair. Good luck
Jun 19, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Canon PowerShot A520 Digital Camera Logo
205 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
