Question about Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television
Screen completely off
My TV will just go off  - when you try to turn it back on, you get an EOI code.
I checked the manual and all connections are correct - please advise
  • ddingle1 Dec 24, 2008
    One of our client's has the same set with the same problem. We followed the previous poster's suggestions and checked the power supply board for bad solder connections. Our tech noticed several problem areas,but nothing really bad. He touched up anything that looked bad and we put in back in place.
    I will post the results after a month or so of use.
    Thanks for the tip! Hope it works
  • howardgraves Apr 23, 2009
    Exactly......I have been told the major cables from the receiver to the screen are at fault......now looking for replacements.....I live in Chiangmai and Bangkok is looking.......does anyone know where they might be purchased? Thanks, hcg
  • 3 Answers
I found this possible solution in another forum - I really hope this will help you out twister50... As an electronics design engineer this sounds as if it could well be the cause of your problem... Good Luck!! - Rob UK
I had exactly the same problem with my 503HDE. Screen would randomly shutdown and display E01.
In my case I believe that the cable was not at fault. The power supply in the media box looks like the most likely culprit.
I dismantled the media box and removed the LARGE power supply board and checked for dry solder joints. Sure enough, where the heatsink was soldered onto the board the joints were in a bad way. I reckon this is a symptom of the fact that the media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone with a reasonable level of IT type skills!
I resoldered the joints and (touch wood) I've not had a problem for over 2 months. Whilst I can't guarantee that this is the definitive fix for this problem it seems to have worked for me. I'd be interested to hear if anyone else finds this cures the E01 problem.
Not being a hardware engineer, my only doubt is why the heatsink is connected electrically to the circuit board. Would this be for earthing purposes or perhaps to do with temperature sensing? Not sure about that - screen completely off - rolleyes.gif
Hope this helps someone - six grand is a lot of dosh to write off!! __________________
Posted on Jan 04, 2008
I have this sony tv model no.KDL 46 VE5 no power at all.what could be the problem?
There's a fuse on the power supply board if not blown change the power board I found one for 8 dollars on eBay.
May 30, 2014 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung DV3 tv only shows static. I'd unplugged it to put in another room. Now back in its original place with correct connections. How can I acquire code for rc unit?
Try searching online for the remote owner's manual using the remote's brand and model number. The owner's manual will have the codes you need to reset your remote. Check out Remote not working for more tips and solutions.
If that's not the cause of the static on your TV, your next step is to troubleshoot TV issues. Check to make sure your TV is set to the correct channel, generally channel 3 but in some areas channel 2 or 4. Also call your service provider to make sure it's not a service outage.
The problem could also be an issue such as disconnected or improperly re-connected cables, as well as problems with the capacitor or backlight. For more causes and solutions, check out this handy troubleshooting checklist in TV black screen or snowy screen. I hope this helps!
Sep 13, 2012 | Samsung Televison & Video
Hi gud noon.just want some advice i have a problem with our tv sanyo flat screen if we try to turn it on it only appears blue screen theres no picture....thats our problem... we try to call already the...
  1. Try changing the input on the TV to see if the Blue screen goes away. Can you access the TV menu on the screen? If so, try running a channel scan until it is complete. Then check if the blue screen is still there.
  2. Disconnect any RCA cables, or other input cables from the back and see if you still have a blue screen.
Here is the link to Sanyo's Support site: http://us.sanyo.com/Customer-Support
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 25, 2011 | Sanyo DP32648 32 in. LCD TV
Xbox 360: colour/display failure
most likley a cable issue if you are using hdmi make sure its fully homed in same with the others but have you checked the display settings on your xbox? otherwise borrow another cable just to find out
Aug 06, 2009 | Microsoft Xbox 360 Console
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
RCA F36689 when I turn on ,Cuts off, then back on then off
Possible bad IHVT or bad solder connects....T.
Dec 10, 2008 | RCA F36689 36" TV
Just purchased Xbox 360. Have everything hooked up to the TV as per instructions. Nothing comes up on the TV. Anyone know why to help me out? Thank You, Jerry
On most TV's nowadays you have to put the TV into Auxiliary or Aux mode. Most TV's with that Feature have a separate button on the TV itself, and/or on the remote control marked Aux, or Video, or Game or something to that effect. Usually you know its in that mode by a completely blue screen, or completely black screen.
Also, recheck your connections to make sure your Video and Audio inputs are matching the color coded input ports in the back/side of the TV. In a poorly lit room its very easy to fudge the connection color-codings. Also make sure the cable is firmly connected to the back of the X-Box and that the Selector switch is set to Standard Defition-TV if only 3 of your Composite cables are hooked up. Or if all of them are plugged in and you have an HDTV, that the selector switch is set to HDTV.
May 15, 2008 | Video Game Consoles & Games
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Dec 28, 2007 | Televison & Video
Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Logo
432 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
